Page 1 of 2 12 LastLast
Results 1 to 25 of 26
Thread: What is involed in removing entire aircon from my VT
    SMIT's Avatar
    SMIT is offline Donating Member
    VT C2R TURBO 5SP + CRUNCH VE SSV 6SP
    Aug 2005
    Mornington Peninsula, Victoria
    Default What is involed in removing entire aircon from my VT
    Hey guys,
    I need to remove my air con from my car, what exactly is involved in removing the system?
    Do i need to release gas from somewhere before i start removing it? and what exactly can i remove? are the demisters and heater seperate from the air con or are they the same system (if i remove one to the rest go with it?)
    What about the compressor on the engine also can i remove that?
    Is there any legalities i need to know?
    The reason im doing this is because its getting in the way of my new setup, some air con canister (?) is right up again the external gate (see pic), and that thing gets mega hot.
    Attached Thumbnails Attached Thumbnails What is involed in removing entire aircon from my VT-picture.jpg
    VY SS
    Jun 2006
    Albany
    take it to a pro to get it removed cause it needs to be professionaly de-gased
    SMIT's Avatar
    Aug 2005
    What is exactly is professionally degassing? as i would prefer to do it myself/ Save money.
    VZ Tonner 3.6L
    Oct 2008
    Quote Originally Posted by kinkbike_rider View Post
    Hey guys,
    the only legalities would be you cant just let the gas go into the atmosphere, you need the proper reclamation gear only a registered air conditioning specialist/mechanic would have. (although a lot of people will just let it go, i'll leave it up to you)
    If the a/c compressor runs on its own belt, not around alternator etc it can be removed,other wise try and get a smaller belt. you can then remove all lines back to the firewall, and even the condenser in front of the radiator as it wont be used. that canister can be removed and is a type of accumulator (stores oil to help lubricate compressor). there's no need to remove the evaporator box (which contains heater core and evaporator core etc under your dash.)
    VZ Tonner 3.6L
    Oct 2008
    letting the gas go into the atmosphere contributes to global warming
    SMIT's Avatar
    Aug 2005
    Quote Originally Posted by alloytech32 View Post
    I knew someone was gunna say it....
    SMIT's Avatar
    Aug 2005
    OK thanks, will it be used though at all? if not i might as well remove it.
    VZ Tonner 3.6L
    Oct 2008
    well your heater core is in it so if you remove it you wont have a heater and you will have to block off your coolant heater hoses in the engine bay. havnt removed a vt evaporator box before but gennerally your blower fan for your vents is all apart of the evaporator. so if you can do without all that you'll be right!
    curious, what motor have you got in it?
    VZ Tonner 3.6L
    Oct 2008
    haha yea the greenies dont like it....
    Ozzie's Avatar
    Ozzie is offline JCCC Warrnambool
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    SMIT's Avatar
    Aug 2005
    just an ecotec mate, just recently had it done. Still in the process of fully setting it up.
    nicko's Avatar
    nicko is offline Carbon Positive - DO IT!!
    75 cruiser ute
    Sep 2007
    sa
    any greenies? out there i released a 7kg gas bottle on my driveway today lol
    no longer a hoon by association - the commodore is gone
    commsirac is offline Banned
    vx
    Aug 2007
    Why dont you get an aircon specialist to put whatever is it somewhere else where it will fit, its just a matter of plumbing. Then you will still have aircon.
    Release the gas yourself? All you have to do is push on the schraeder release valve....its just like a tyre valve. But this is going to be messy and dangerous, r134a poisoning and cold burns for yourself.....and easily cost you more getting medical attention than getting someone with the right gear to do it for you.
    Quote Originally Posted by nicko View Post
    LOL?, because you are a vandal? Assuming it wasnt just compressed air!
    Of course you will affect EVERYONE if you release it into the environment.....contrary to the view that only greenies live on planet earth. About the same level of disregard as taking a leak in one of our drinking water dams.
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by commsirac View Post
    That's what I would do. It couldn't be to hard to get new hoses made up.
    MY RIDE
  15. #15
    VT Commodore S1
    Apr 2007
    Kempsey, NSW
    why not just get a heat blanket for the turbo. If you try and remove any part of the aircon system you will need to have the gas recovered professionally, otherwise i would wish the fine on you for stupidity and ignorance. You could only ever remove the system from the firewall forward as you still need to retain your heater core and vents to have use of the demister, which is a requirement for rego. Do the right thing and take it to a aircon place and tell them what you want to do. It should cost you less than $50 to have it recovered correctly, instead of a $5000-$10000 fine.
  16. #16
    Fr3ak+--'s Avatar
    Fr3ak+-- is offline Closed On Monday
    Vt Exec 5 Speed
    Jul 2006
    Kingswood, Nsw
  17. #17
    Tom_1569's Avatar
    Tom_1569 is offline Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    A mate released his himself. He didnt expect it to have so much pressure in it. Released it and it shot straight out all over his face and arms. He recons he ran blinded to the damn and jumped straight in. LESSON LEARNT!!!
    Just get it professionaly degassed, saves injuring yourself, and if you live in town then your affecting the people around you aswell or they could report you to the EPA.
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
  18. #18
    hsvpunk's Avatar
    hsvpunk is offline volunteer firefighter
    vy ss II M6
    Jan 2007
    Mornington, Vic
    Smit, im sure Steve (morno motors) would know where, or who can get rid of it for you.
    Im keen to see your car now. with this 'new' setup.
    dont worry, il start a ride thread soon.
  19. #19
    SMIT's Avatar
    Aug 2005
    i called around today, cost around $20 to get it done professionally (?). so i guess ill do that, the problem is i just have to get it their without a tuned memcal. 400 posts (yay!)
    i had a quick look and the compressor looks like it runs on the same belt as everything else? so what do i do here? remove it and just get a smaller belt? also can i remove everything except the compressor and leave that there or is that a bad idea?
  20. #20
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    You can get a shorter belt for non A/V V6, so you can remove the compressor and you will have to remove the idler pulley near the compressor. I have a shorter belt here which I bought at Supercheap when I had a VT.
    MY RIDE
  21. #21
    BOGANV8's Avatar
    BOGANV8 is offline I gotta V8 whoot whoot
    VX 02 SS LS1
    Dec 2005
    Armidale
    When i did my Automotive A/c course bout 4-5 years aga R134a was not dangerous to the atmosphere unless things have changed.. Use to always un screw the vavle on R134a systems slowly just so it hissed out a litle bit and then come back in like 2 hrs and do the A/C service and then regas.... But this was in the days when we were also doing lots of retrofits R12- R134a..... Good old R12 nothing colder than that crap..
    But like i said things may have changed since then and i have not kept up to date with it the rules and regs..
    Also what happens to a car when its in a prang and the A/C system is smashed im sure it hits the atmosphere then it a big way.. Silly greenies
  22. #22
    vt acclaim
    Mar 2006
    Gladstone Qld
    Quote Originally Posted by BOGANV8 View Post
    This is why they should make that crappy "automotive a/c course" totally illegal. R134A may not have the chlorine component to kill the ozone BUT it still has a G.W.P
    The only refrigerants that are ok to be released are R717 (NH3) & R744 (co2)
    It takes four years to be a licensed refrigeration mechanic, yet mechanics and auto electricians can do a short course on the best way to kill the environment and do poor a/c repairs. should be stopped!
  23. #23
    Cursed CX8 is offline Banned
    VY Adventra
    Feb 2008
    Walking distance to FG meets
    Hey guys,
    that part made me laugh. Your turbo-charging your commodore and your worried about the legalities of air con lol.. Id be more worried about the legalities of the snail
  24. #24
    VZ Tonner 3.6L
    Oct 2008
    unlike R12 gas, R134A refrigerant isnt an ozone depleting substance, but it still acts like a blanket in the ozone layer (global warming) along with all other pollution. if you want to be technical haha
  25. #25
    vx
    Aug 2007
    When i did my Automotive A/c course bout 4-5 years aga R134a was not dangerous to the atmosphere unless things have changed.. )
    Nothing has changed in the last 4-5 years, the gwp of r134a has been known since its introduction and I dont believe it has ever been acceptable to discharge it into the atmosphere.
    Where did you do your automotive ac course?
  1. Removing aircon...... VS
    By Cobez in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-02-2008, 05:19 PM
  2. removing aircon
    By PaRaDoX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-11-2006, 12:24 AM
  3. Removing aircon controls, mode switch, light switch
    By wrx884 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-03-2006, 10:53 AM
  4. 25% Off Entire Range
    By Holden_Mechanic in forum VY Holden Commodore (2002 - 2004)
    Last Post: 24-10-2005, 11:14 AM
  5. 25% Off Entire Range
    By Holden_Mechanic in forum General
    Last Post: 24-10-2005, 10:32 AM
