Results 1 to 2 of 2
Thread: VT vacuum line trouble
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    Default VT vacuum line trouble
    Hi,
    VT recently refused to start. Seeing as its my old mans and he is away i decided to diagnose the problem.
    It kept turning over nearly firing, i got it running for a second but it just coughed and spluttered then died. I persisted and pumped the throttle as it was turning over and it fired finally, I kept the revs up around 2k for a few minutes, it ran fine but idle was very rough and nearly stalling.
    Anyway i noticed a loud hissing when i was revving which told me it had a vacuum leak so i removed the engine cover and inspected the throttle body to find a disconnected hose on the underside of the TB which led through the plenum to what appears to be a sensor attached to the back of the motor, with 2 hoses and a electrical connector attached to it.
    Firstly what is this sensor?
    I reconnected the hose back to the TB and the motor now fires and runs fine again, though the hose is very loose fitting, its a flexible plastic hose not rubber and there are no clamps to secure it at either end so whats the fix for this? I don't want it coming off again. I'm thinking of using some hose clamps?
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    It's called the purge hose and it is a common problem for them to come off. You could buy a new one or use a clamp.
    MY RIDE
  1. V8 Throttle body on V6 VN - 1 less vacuum line?
    By wilso in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-07-2008, 10:34 PM
  2. where does vacuum line go?
    By aidaniel in forum VL Holden Commodore (1986 - 1988)
    Last Post: 01-06-2008, 08:04 PM
  3. vacuum line
    By 10000_fists in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-01-2007, 10:27 PM
  4. vacuum line
    By naf33n in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 09-04-2006, 07:54 PM
  5. what vacuum line for crs supercharger?
    By gmhvr-6 in forum V6 Development And Modification
    Last Post: 05-09-2005, 06:38 PM
