Results 1 to 6 of 6
Thread: noise in drive belt area lsi hsv
    VT HSV
    Jan 2006
    Default noise in drive belt area lsi hsv
    have a like a grating rattling bearing noise in drive belt area . just wondering what the most common fault would be . souds like its in the top tensioner pulley . would it be in another area .
    MY10 SSV UTE
    Dec 2006
    Melb
    VT HSV
    Jan 2006
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Grab a short piece of hose or pipe and hold one end to your ear and the other end as close as possible to the pulleys one at a time and you should be able to hear which one is the culprit.
    You can also use a large screwdriver, put the plasic handle to your ear and the blade somewhere on a non spinning part of the pulley.
    MY RIDE
    vn/vp Speedway Street Sedan
    Sep 2005
    Common one is the idler pulley. But alternators, powersteering, water pumps and aircon compressors can all be likely culprits.
    Take your belt off...(dead easy job) and spin each component by hand and see if one is a bit tight or rumbly.
    Check it out properly... cos if your travelling down the highhway one day and that pulley seizes, you will burn the belt off straight away and probably cook your engine before you know something is wrong. = BIG $$$$$$ Repair.
    Good luck.
    VT HSV
    Jan 2006
    yep water pump was stuffed . replaced that along with others .water pump not cheap.
  1. New drive belt
    By WJD634 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-10-2008, 10:51 PM
  2. Drive Belt.
    By Tam in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-08-2008, 07:49 PM
  3. Drive belt noise after new pulleys
    By hN! in forum VY Holden Commodore (2002 - 2004)
    Last Post: 12-04-2008, 01:47 PM
  4. Drive belt ?
    By BLACK-2002 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-10-2007, 09:38 AM
  5. New Drive Belt Noise
    By drob1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-07-2005, 09:28 PM
