hey folks,
i want to put the power windows/seat in from my s-pack, and ive been told the wireing loom will need to be changed.
the vt im changing it to allready had an electric seat & plugs there, but it didnt work (maybe a dodgy electric seat??)
ive basically got the whole interior out besides the dash, which theirs only 2 screws holding it in becausde i want to get the air con checked before i remove/replace the dash..
could someone please explain what needs removeing and replacing so i can put the power windows and seat in??
I just plan on taking the doors off the s pack and spraying them, rather then changing all the electric window stuff into the other doors.
thanks.
PS - DOES ANYONE KNOW HOW TO GET THE PINS OUT OF THE HINGES ON THE DOORS ???
Have you checked the fuse (circuit breaker) for the seat?
Installing the power window regulators into you doors is quite easy and then all you need to do is change the looms. Respraying the doors is not going to be cheap unless you know someone and then they may not match the rest of your car. But if you want to change the doors then the hinge pins are removed by knocking them out with a puch or something similar.
MY RIDE
hey
i just plan on keeping the doors off the s pack because they allready have the regulators in them, saves buggering around amd changing them.
how do i install the loom for the power windows ?
also, anyone got any good ideas for getting the pins out of the door hinges ?? near impossible to get even a small punch to the top hinge pin..
