Results 1 to 8 of 8
Thread: VX Equipe factory Alarm Problems
    ScoHar's Avatar
    ScoHar is offline Jizz in my pants
    02 VX Equipe V6
    Apr 2006
    CHCH, NZ
    Angry VX Equipe factory Alarm Problems
    I know this has probably been covered before but at least if I do this then I can cover all my bases, My VX equipe wagon has just started playing up after 135,000kms of holden driving pleasure.
    The factory alarm is giving me grief, Its fine when the car is locked and as soon as you unlock it, the alarm sounds, now to stop this happening in the mean time I've removed the wire off the alarm horn (behind LH strut tower) and car still starts (no immobiliser?) so alls good for now, but would like to sort this out.
    Things I've tried,
    1. Removed Battery/replaced battery
    2. used spare key to lock and un-lock
    3. checked all doors including boot and bonnet
    4. tried not using the remote and using just the key in barrell
    5. checked voltage across the battery terminals when lock/un-locking
    they all seem fine and I'm running into the end of this now, if anyone can help that would be great.
    ScoHar's Avatar
    02 VX Equipe V6
    Apr 2006
    CHCH, NZ
    come on people, someone must have had this problem before, 5 more days (its been 3 months) and Is going into holden, so if you have the same problem ill let you know what it was.
    VT2 SOCOG Exec 9C1
    Dec 2004
    The only thing I can think of remotely (sorry) similar is my old man's VY with a similar problem that according to the dealer when I asked was the door actuator, usually the drivers side.
    Subsiste Sermonem Statim
    VX Executive S2
    May 2006
    Frankston South Vic
    I would try replacing the alarm relay, but I suspect the body control module has had it
    Doctor Bob's Avatar
    Doctor Bob is offline Grandpa
    VT V6 Exec & VN V6 Exec
    May 2004
    Mornington Peninsula
    ScoHar's Avatar
    02 VX Equipe V6
    Apr 2006
    CHCH, NZ
    Quote Originally Posted by Doctor Bob View Post
    so when you use the remote to unlock the car the alarm goes off?
    Yip, and as soon as you lock it again its fine. Its almost like somehow its half swapped it functions around, e.g alarm set when unlocked, no alarm when locked, well not 100% sure if no alarm when locked, but yea alarm goes off when you unlock the car.
    ScoHar's Avatar
    02 VX Equipe V6
    Apr 2006
    CHCH, NZ
    bump, never ended up taking it into Holden, cars not gonna get stolen (touch wood) and its stops with the wire off the horn/alarm
    VX Berlina
    May 2009
    Alice Springs
    My VX had an issue with the BCM.. what happened was, I was driving home from work and the alarm just went off like beeeeep instead of beep beep if u get my drift.. and the dside window doesnt go up.
    Took it to a dealer and was told otherwise... that it was an issue with my battery and the ecu... not sure if theres any difference in bcm and ecu but yea.
  1. factory alarm?
    By stocky in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-08-2008, 05:29 PM
  2. vz 05 Equipe - Handling Problems :cry:
    By EQUIPED in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 11-02-2008, 12:37 PM
  3. Factory alarm
    By Jeff_H in forum VY Holden Commodore (2002 - 2004)
    Last Post: 26-04-2007, 08:05 PM
  4. vs equipe alarm help
    By danny1987 in forum Electrical Wiring / Questions
    Last Post: 08-03-2006, 06:08 PM
  5. vs equipe alarm help
    Last Post: 27-02-2006, 07:06 PM
