Results 1 to 4 of 4
Thread: putting headlight switch back together
    VX Commodore Lumina
    Jan 2006
    South Adelaide
    Default putting headlight switch back together
    I'm just wonering how the hell I'm supposed to get this headlight switch back together. I've taken it apart to change the lights, but I can't for the life of me work out how I can get the shaft thingy into the backing with the ball bearings in place.. Whenever I try and put both in, the spring just shoots the other one out he other side. Is there a special trick to get the thing back together? (I'm talking about the bit that makes the switch 'click' from one light option to the other.
    vs commodore sedan
    Jul 2005
    i found putting it together in 2 parts easy first by putting the main housing and dimmer together then putting the backing and the main shaft (the centre one) together then slide the 2 together
    Philthy's Avatar
    Philthy is offline That dent guy
    VS Berlina, XC AMS Project
    Aug 2005
    I ended up gluing one to the spring, and using a tiny screwdriver to get the other one in.
    ****ed if I will ever pull the thing apart again though! Easier just to buy another one
    EDIT: This was in a VS, I assume they work pretty well the same way
    VX Commodore Lumina
    Jan 2006
    South Adelaide
    Quote Originally Posted by danny1987 View Post
    Yeah that's all good mate, but how did you get bot of the bearings into the main shaft before going into the backing?
    I've tried to press them both in from each end, compressing the spring, but it just slips out when I go to put it in place, and one time they both went flying, so I was crawling around like a sniffer dog trying to find both of those tiny bearings on the lounge room floor lol. Luckily I didn't find them though!
  1. trouble putting brake calipers back on
    By muzza in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-08-2008, 02:00 PM
  2. Headlight Switch
    By Dayvo in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-08-2008, 07:58 PM
  3. putting fan shroud back on.. on 5L
    By VNexecutive in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-11-2007, 10:50 PM
  4. Help!!! Putting fuel tank back in with new breather hoses..
    By Kartbro in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-01-2007, 11:25 AM
  5. putting 202's carby back on
    By Bush VB in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 06-09-2005, 04:25 PM
