Results 1 to 18 of 18
Thread: Undoing Cooler Lines
    VX Calais 01 3.8lt Ecotec
    Jul 2006
    Default Undoing Cooler Lines
    Mechanic has overfilled my transfluid a few weeks ago, and i wanna drop it out. It seems my cooler line bolts are stuck, any advice for loosening them ? I am turning them anti clockwise facing engine but scared i may kink or damage the metal lines......
    Thanks.
    ve commodore ss
    Sep 2008
    your better of taking it back to your mechanic. they did it they should fix it. you dont want to make things worse.
    Jul 2006
    I dont wanna take it back unless i have to, I only need to drain a litre. I will eventually flush all the fluid, but its currently too high in level.
    Sep 2004
    Jul 2006
    The guy who did it is usually very good. I gave him 4 litres when doing my trans change over and few other things. He told me is still needed another litre. SO as i startign adding, when i got to 300ml, i realised it was already too high. I just need to drain a litre or so.
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    mate of mine uses a huge syringe with a long hose on it - stick the hose down the filler pipe and suck it up ...
    Jul 2006
    lol. thanks peoples, i just wanna undo the bolt hehe Dont give me ideas as i may try to suck it out like i did with engine oil once, should have seen the healthy fumes i was exhaling...
    VTS5's Avatar
    VTS5 is offline TechJunkie
    '97 VT Spack 5 Speed
    Jul 2005
    Sth.East\Melb
    Quote Originally Posted by vxcalais_01 View Post
    Thanks.
    Why dont u take it out from the radiator side?Its easy and neat.Put the hose into container crank the engine once or twice,done..
    Jul 2006
    Quote Originally Posted by VT_Acclm View Post
    THats exactly what i am trying to do, see from the image >? I am stuck with these bolts, not sure if turning it correctly......the cooler line bolts...
    ScoHar's Avatar
    ScoHar is offline Jizz in my pants
    02 VX Equipe V6
    Apr 2006
    CHCH, NZ
    Don't undo that one, undo the one that has a hose clamp on it, currently doing the exact same thing to a VY SS, on the right hand side at the bottom front near the radiator is where they have a little rubber hose section, undo the hose clamp holding it on and bam done.
    Jul 2006
    Quote Originally Posted by hartsc View Post
    Can you do a little sketch ? It seems like the metal tubing continues on to the radiator, its been tie stripped to something. I can see the rubber hosing only on the pipe that runs to the engine..... So where it connects directly to the radiator, there should be a rubber hose clamp ? That would be easier....i need to have a look, thanks heaps....you sure thats not the power steering ???
    BOGANV8's Avatar
    BOGANV8 is offline I gotta V8 whoot whoot
    VX 02 SS LS1
    Dec 2005
    Armidale
    Attached is a pic of what your looking for i think if yours is a V6. the pic on the top right of the page is prob the easiest...
    Jul 2006
    Thats exactly what i have and pic i seen, see the pipe he is sticking the hose onto, its that bolt i cannot undo, turn left or right to loosen.....? Its to tight, the metal tubing is moving with it.....my sketch shows this pipe connection.
    BOGANV8's Avatar
    VX 02 SS LS1
    Dec 2005
    Armidale
    AHHHHH ok now i see i guess you can try to hammers one on the backside of it and hold against it then lightly tap the other on the side of the pipe to maybe break up the thread sealant if any was used and try to spanners and keep trying..
  15. #15
    Jul 2006
    Yeah, must have been the guys who did the radiator, maybe used some tape on it. Been ages since i pulled a radiator..I will hit it with some WD-40/Inox and see how it goes....turn clockwise, or otherway is what i need to know.
  16. #16
    BOGANV8's Avatar
    VX 02 SS LS1
    Dec 2005
    Armidale
  17. #17
    Jul 2006
    Thanks heaps Bogan...when i was applying force either way it moved. Now i can support one side with a seperate spanner(smaller nut and thread that is screwed onto).
  18. #18
    Jul 2006
    OK, facing the engine, the bolt has to be turned to the right to loosen it. I got if off. Following the diagram i post number 12, funnily enough the one with the hose on it, when i put a hose on that one(pipe leading to radiator, instead the fluid came out of the hose coming from the transmission, what a mess it made grrr, is this correct ? Its the return hose, but the fluid coming from the trans ??? But that darn pic he is draining it from the hose where it didnt come out when i turned on my engine.....
  1. Help lines
    By Lizzard in forum Jokes/Humour
    Last Post: 22-09-2008, 09:45 PM
  2. New Vacumn Lines
    By Pub247 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 09-05-2007, 05:38 PM
  3. V8 Trans cooler lines
    By broderikb in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 27-06-2006, 10:03 PM
  4. undoing towbar bolts on a VL wagon
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 14-04-2006, 08:44 AM
  5. All these bloody vac lines...HELP
    By pro_gmh in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 09-10-2005, 10:38 PM
