Results 1 to 8 of 8
Thread: vx spac supercharged ROUGH COLD START HELP!
    vcxs2
    Sep 2008
    Default vx spac supercharged ROUGH COLD START HELP!
    ive been searchng through the forum and cant seem 2 find any definitive help.
    plz dont flame.
    but my old man is bugging me to fix his vx supercharged commodore.
    it has a really rough idle on cold start
    we have changed.
    leads
    plugs
    cleaned throttle body
    new o2 sensors.
    new fuel filter
    it doesnt seem 2 have any obvious vacuum leaks.
    where else should i be looking. car has less than 70000kms on it.
    fuel pump?
    is there a way 2 check for error codes using the dash display ?
    thanks guys.
    2000 VX Calais 3.8L Supercharged
    Jul 2006
    vacuum leak imo, could be anywhere... i guess youve checked the usual spots, under TB ect. try around your injectors coz the orings crack sometimes, and even if a hose is pulled off the vacuum tank behind the glove box is a notorious spot...
    yes you can check error codes, search the forums for the how-to.
    VY SII HBD Calais L67
    Dec 2006
    Has any work been done to the car prior to this problem starting? Probably a vacuum leak. The L67 has a maze of vacuum hoses but like the other bloke said, check the one under the TB that goes around the back of the charger to the drivers side head. It can slip out if it is touched lightly and will cause a rough idle and high revs on cold start.
    Any probs when driving at revs?
    vcxs2
    Sep 2008
    no problems once the car has warmed up . will double check for vacuum leaks
    is there a way 2 check that the solenoid in the idle control unit is operating correctly
    Dec 2006
    There is a volt range test but it's better to check the manula for that stuff. Wouldn't hurt to remove the TB and clean it
    VT Series 1 V6
    Jan 2008
    vcxs2
    Sep 2008
    VT Series 1 V6
    Jan 2008
    Nah, I've had a fuel pump go on another car and the only indication of any problem was rough start up then ran fine after start up and started fine when hot (I guess coz there was still fuel in the rails), then one day going around a corner the car just died. It's just another option to check (would also include checking pump relays, fuel pressure etc).
  1. V8 running rough / missing when cold
    By VeePee8 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-05-2012, 03:23 PM
  2. Supercharged VT Spac - Going cheap...
    By skyquez in forum Vehicles For Sale
    Last Post: 29-11-2007, 05:43 PM
  3. 91 VN Rough Idle When Cold
    By tep_aus in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-02-2006, 07:27 PM
  4. My Black Beauty VX Spac Supercharged V6
    By blofly in forum VT - VX - VU - WH - V2
    Last Post: 29-01-2006, 06:55 PM
  5. Can't start cold except for clutch start.
    By Holdfast in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-08-2005, 07:30 PM
