Results 1 to 24 of 24
Thread: What is this pully called?
    sxc_sound's Avatar
    sxc_sound is offline getting Kustom
    VT Series 2 S pak
    May 2008
    Parkdale
    Default What is this pully called?
    My car has a high pitched squeal, and i was putting a new belt on today and worked out what pully it was making the noise, it sounds like the ball bearings are stuffed, i lubed it up but no luck. What is this pully called and how much to replace it and how to replace it:
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Cant see the pulley as the photo is too dark.
    On the VN's it's the tensioner pulley that make the same noise your talking about.
    and 3 Dangerous non ABS VN's
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by sxc_sound View Post
    Click image for larger version.
Name:	noisey pully.jpg
    It's and idler pulley and is around $30 to buy.
    MY RIDE
    sxc_sound's Avatar
    VT Series 2 S pak
    May 2008
    Parkdale
    Quote Originally Posted by accentstencil View Post
    cool thanks, how do you remove them? is it as simple as undoing the bolt in the middle of it and bolting on a new one?
    sxc_sound's Avatar
    VT Series 2 S pak
    May 2008
    Parkdale
    VS L67 Statesman
    Oct 2006
    Melbourne, VIC
    Yeah that's the one you want (if you are sure it's the one that is stuffed). Not sure what Holden sell them for, but most spare parts shops sell them for around $30.
    '97 VS Commodore + '98 E36
    Apr 2005
    BOGANV8's Avatar
    BOGANV8 is offline I gotta V8 whoot whoot
    VX 02 SS LS1
    Dec 2005
    Armidale
    While your at it and if ya can spare the cash do all three tthe 2 on the left side of the motor (1 grooved 1 not grooved) and the 1 on the tensioner (the bolt is a left hand thread). Cause at the end of the day all 3 pulleys have been spinning over the same amount as the one that is making a noise....
    So better to do them at the same time save doing it later as it will only be a matter of time before the other ones get noisey..
    daron's Avatar
    daron is offline wizfiz
    VE SSV
    Mar 2006
    adelaide
    theres a reson behind why its platic on some pullys and thats so it doesnt squeel
    also remeber some pullies are backward threads
    sxc_sound's Avatar
    VT Series 2 S pak
    May 2008
    Parkdale
    thanks for the info guys, its been heaps of help, im going to have a look at supercheap auto tomorrow to see if they stock the pulleys, i might replace all three as mentioned. Does anyone know what stores would stock the pulleys? supercheap auto, repco, autobarn?
    BOGANV8's Avatar
    VX 02 SS LS1
    Dec 2005
    Armidale
    Repco i know has them for sure havent had much to do with supercheap or any of the others as repco tends to look after me
    pablo is offline Donating member
    Was a 1997 vt v6 wagon
    May 2006
    Super Cheap have em in Adelaide. More than likely other states as well. If you get the K.C. (Kilkenny Castings) brand, the bearings can be easily replaced if they ever get noisy again. Don't know 'bout other brands!
    Pablo
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    i need to replace (in my vs) the one directly under the one in pic as it has sideway movement in it....the others were dry but i greased the bearings and there fine but this one is stuffed though.....i have to get a price tommorow
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    well i went and brought the one for mine today and also the one you need to be on teh safe side. The ones i got were metal ones and cost me 25 bucks each.
    brand were NULINE
  15. #15
    sxc_sound's Avatar
    VT Series 2 S pak
    May 2008
    Parkdale
    ok, iv bought my new pulley from repco, HOW THE HELL DO YOU REMOVE THE OLD ONE, that bolt is sooooo damn tight, that i broke 2 spanners and a socket trying to get it off, and yes i know its a left handed thread, how the hell do people get them off?
  16. #16
    BOGANV8's Avatar
    VX 02 SS LS1
    Dec 2005
    Armidale
    Are you trying to do the tensioner one if so...
    Grab a socket and a 1/2 inch crack bar and push on the tensioner so standing on the drivers side of the car push the bar towards the pas side and it will come loose as its a left hand thread..
    For the other 2 use the same crack bar with the right socket and undo normal as they are normal threads on those..
    See pic below
    Attached Thumbnails Attached Thumbnails What is this pully called?-pic-jc.jpg
  17. #17
    sxc_sound's Avatar
    VT Series 2 S pak
    May 2008
    Parkdale
    success!, i got the pulley off and put the new one on, very happy with it, it is so much quieter now. i will replace the other 2 pulleys later down the track, thanks for all you guys help
  18. #18
    BOGANV8's Avatar
    VX 02 SS LS1
    Dec 2005
    Armidale
  19. #19
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Only the tensioner pulley is left hand thread, the others are right hand thread.
    MY RIDE
  20. #20
    sxc_sound's Avatar
    VT Series 2 S pak
    May 2008
    Parkdale
    Quote Originally Posted by BOGANV8 View Post
    did ya do what i said last night with the big bloody bar....
    sure did, thanks for the help, worked a treat
  21. #21
    Full Spectrum's Avatar
    Full Spectrum is offline Customize your life.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    You might just be experiencing the squeakatech in action. Most VT V6's if not all sometime or other have it, Mine has it right now.
    Some wd40 on it will quieten it down until changed.
    Quote Originally Posted by Yoda
    Do, or do not. There is no 'try'.
    <img src=http://forums.justcommodores.com.au/signaturepics/sigpic440_66.gif border=0 alt= />
  22. #22
    vt executive
    Jul 2008
    sunshine coast
    Quote Originally Posted by r_i_d_a_h View Post
    dont buy the holden plastic crap.
    get the after market ones from auto spare shops as they are metal.
    Yeah those top ones do go!! after market is better (repco) one bolt I had one on my front seat to go in when the old one let go at 110km bugger most of the time belts just fall off naa not mine rapped around harmonic balencer ripped out crak angle censor and wireing turn a $25 into a $400 one .
  23. #23
    VS Executive BT1
    Nov 2008
    Deffinately replace all the pulleys as I had total bearing failure in one pulley, snapped the pulley off the pedestal and threw belt off which wrapped around the harmonic balancer taking out balancer, crank angle sensor & cam angle sensor. Luckily I could do all the labour but parts alone at trade prices ran me more than $600. A $30 pulley seems extremely cheap, ahh hindsight isn't it a wonderful thing..... Also be aware that there can be different outside diameter of pulleys on series one or series two cars so make sure you get the correct pulleys for your engine model year.
  24. #24
    s_t_r_e_t_c_h's Avatar
    s_t_r_e_t_c_h is offline WTB: VS SS (VIC)
    VS SS Commodore
    Sep 2008
    Puckapunyal, VIC
    this post is awesome!! will be changing mine this week and this thread cleared every thing up for me.. thanks guys!
  1. What are they called
    By Mossman in forum VY Holden Commodore (2002 - 2004)
    Last Post: 19-12-2010, 07:27 PM
  2. what are these called, and where do you get them??
    By DANVSUTE in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-09-2008, 10:59 PM
  3. You called me?
    By Outlaw Torn in forum Jokes/Humour
    Last Post: 28-06-2006, 12:00 AM
  4. Replacing SC14 stock pully with an alternator pully ?
    By gemini in forum General Discussion
    Last Post: 08-05-2006, 04:02 PM
  5. A/C pully..
    By VL Berlina 5speed in forum VL Holden Commodore (1986 - 1988)
    Last Post: 23-03-2006, 12:14 AM
