folks,
i cant seem to get the doors off, its basically impossible to fit a punch in place to hit the pins out of the hinge.
Can someone who has taken the doors off explain exactly how they did it ?
thanks folks
easy get long nose plyers grip the end that flairs out and hit the plyers with a hammer, try a bit of rust off or wd40 do it all the time at work if your in sa i'll come and help if ya no to far
try vice grips instead of pliers, it can be done, i've done it, just takes a lot of patience.
yeah and make sure you have the snap strap out and the door loom
You can also use a drill bit to drift them out but i recomend if you do this to wear safety glasses just incase the drill breaks .
