My VX Calais Supercharged wont crank over occassionly. It only happens once every 4 weeks or so, but its still doing my head in. I turn the key and get the lights and radio but the engine wont crank. Then if you try again after leaving it for some time it works. I've taking it to Ultra tune and they cant find the problem. They've tested batteries and alternators and connected to the diagnostics of the computer and still nothing,
C'mon boys, who can help,
cheers
maybe it might be in the shifter?
Happens to my VT on the odd occasion. It looks like its in Park but when I tap it, the engine turns over.
yeah mate tried that aswell,
it's got the mechanic stumped,
cheers
Dirty contacts at the solenoid to your starter motor. You'll have to take the starter motor out to change the solenoid.
Was going to say the same thing. Check the lead from the battery to the starter, make sure it is tight and that the plastic solenoid cap is not loose.
I had a similar problem once and it was the inlet manifold gasket gone and some coolant was leaking in to no 1 cylinder therefore the first time it would not crank and bit by bit the exhaust valve opened and pushed the coolant out the exhaust then the engine would crank and start it was exactly the same as a flat battery.
It could be your crank angle sensor happened to my vt costs about $120 to get fixed.
do you hear any click from the starter at all when faulting?
most likely starter relay,
does the red alarm light flash when u try to start could be the key or key reader
could be the immobiliser playing up
I live not far from Bosch, the mechanic i took it to has taken it to a company that works for Bosch, they are going to run a full diagnostic on it. I'll let you know what it is.
my s2 vt that i just brought is doing the same thing, it turned off when my dad was driving it aswell, lucky he was parking. mine's getting looked at by holden on saturday
yes please do let us know and them we'll both know LOL
|VT Olympic Edition 3.8L Ecotec | VY S Pack Green Interior|
Mods to come | VY Map Reading light/Sunnies Holder|
"Give me a minute, I'm good. Give me an hour, I'm great. Give me six months, I'm unbeatable."
My ute is doing the same thing, when i try to turn it over all you hear is click click click. & sometimes it starts up fine.
ill be looking at the starter tonight to see if there is somthing loose.
my son's car did the same thing, would not start some times and would also stop in traffic, bl**dy dangerous in the city. It finally came down to the crank angle sensor.
hey, took it to holden and it was the crank angle sensor that was stuffed up, cost $206 to replace. hasnt stopped a beat sincehope this helps you guys
That's why we are all here "Clark522", good one mate, happy cruising.
my car is doing the same thing except i have replaced my crank angle sensor and i scanned it with our diagnostics tool at work and it came up with crank/cam angle sensor so im stumped does anyone know where the cam angle sensor is ??????
