Hey guys,
Just wondering if anyone has done this? Is there somewhere convenient to fit the sender? Like a T piece or is there a sandwich plate available to take a sender between the block and filter or something?
This is for a VT series 1 V6 btw.
Thanks all.
I am looking at doing the same thing, only I want to monitor oil temp aswell I belive for oil presure its as simple as putting in a T piece and connecting your new sensor. I am not sure if this is the ideal place to take a tempreature reading.
Check out Speco com au they sell T pieces and a oil pressure/oil temp plates for between the oil filter and the block.
Part numbers below (thou I myself am still trying to work out which one).
~$12
ELECTRIC OIL PRESSURE
T-PIECES (BRASS)
547-60:
1/8" NPT (A) x 1/8" NPT (B)
x 1/8" NPT (C)
547-61:
1/4" NPT (A) x 1/4" NPT (B)
x 1/8" NPT (C)
547-62:
1/8" BSP (A) x 1/8" BSP (B)
x 1/8" NPT (C)
OIL PRESSURE
AND OIL TEMPERATURE ADAPTORS
Oil filter mount
~ $40
547-49:
13/16"–16 oil filter thread. Suits V8 Commodore, VN onwards, with 2 3/4" o-ring.
547-50:
3/4"–16 oil filter thread. Suits most Ford, Toyota, Nissan.
547-51:
18–1.5 mm oil filter thread. Suits V6 Commodore, VN onwards.
547-52:
20–1.5 mm oil filter thread. Suits most Mazda, Mitsubishi, Honda etc.
547-53:
22–1.5 mm oil filter thread. Suits Ford V8, BA onwards.
Oh btw, Bursons stock these parts.
i just removed the oil pressure switch and put the oil pressure sender in there.. u just wont get a engine light if you low on oil.. but that's what the gauge is for
Okay, Just come back from Repco, they have a T piece (Part. #230032 $12) that is 1/4" from the block, 1/4" for your current oil pressure switch and to 1/8". The 1/8 is most likely where you will take your electronic reading depending on how long your sensor is. My temp sensor was 2 cm long, and was way to long maybe 1CM to long) to fit in the 1/4 area. So I am now looking at using the Speco 547-51 oil filter/temp adapter ($40). Going down to Bursons tomorrow to see it this will fit my 2cm electronic temp sender.
Yep, Speco 547-51 for V6 VN -Onwards works fine $40![]()
Sweet, you're a legend!! Sounds like the way to go.
Throw some pics up if you can.
sold em for 20 something when i was at autobarn
and just confirming that 547-51 is the right part number
Well installing wasn't fun at all! In the end I had to end up using a G-Clamp to hold the adapter onto the engine block so that the thread of the hollow bolt could actually grip onto the engine block. Not fun at all, so I made sure that I tightened this nut @#$@ing hard as I did not want to journey down this path again.
You will notice in the photos some oil on the floor and near the allen key bolts on the adapter this is because they were not tight enough, so before you install yours make sure that you tighten these as much as you can, as this is a b@#$ of an area to get to with tools after you have mounted the adapter. If mine keeps leaking i might even have to some some high temp tape to use on the allen key bolt threads just to create an air tight seal, but I think this is solved now.
Nice work. It does look like a pain to work on though.
Oh well, keeps it interesting I suppose!!
VT sleeper
did you use a non standard oil filter? When I tried that conversion I couldnt get the standard filter on as it was too long?
thanks is advance
Adrian
i can supply any parts you need mate
SIR LS1
the two ton go kart
