Results 1 to 2 of 2
Thread: Drivers side power window goes up but wont go down
    VT S
    Oct 2008
    Default Drivers side power window goes up but wont go down
    Hi
    Ive just bought a VT S 1998. Yesterday while driving I attempted to wind the power window driver side down and it didnt budge and had a ticking sound coming from under the steering column where the fuses are. I pressed the switch to wind it up and it worked fine but now its stuck up and not going down again. As I investigated where the sound was coming from I found it to be the Drivers Window Relay. I just replaced this relay with a new one and no result. Its still ticking and doing nothing. All the other windows in the car work fine and its only the Drivers Window playing up. If anyone has a clue what to do Id appreciate your help.
    Rishy's Avatar
    Rishy is offline Si Vis Pacem Para Bellum
    VZ SS 6spd
    Sep 2006
    Mirrabooka, WA
    I had this problem last week which I fixed on the weekend, well dad fixed.
    The contacts on the motor were dirty as. Cleaned them up and good as new.
    It involved taking the the whole assembly out and taking the motor apart which didnt take long, putting the motor back together was very tedious.
    My Current Ride 2004 VZ SS Lowered on SSL's
    Rishy's VZ SS
    My Old Ride 1998 VT Acclaim on WH Grange's
    Scotty's Acclaim
  1. Drivers side window problem
    By tommacca in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-09-2008, 08:14 PM
  2. Drivers side window problem
    By onthepony in forum VL Holden Commodore (1986 - 1988)
    Last Post: 04-08-2008, 07:03 PM
  3. Fitting drivers side window
    By Steven M in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-12-2006, 01:34 PM
  4. Drivers side power window off guides/channel ?
    By vsv8berlinawag in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-08-2006, 07:19 PM
  5. drivers side rear window
    By david41073 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-06-2005, 10:03 PM
