Results 1 to 12 of 12
Thread: Audio Speaker Confusion
    VT Acclaim
    Oct 2008
    Default Audio Speaker Confusion
    Hi All,
    I just installed a Kenwood headunit, leaving the front speakers standard, killing the rear door speakers and installing a 6 x 9 instead at the parcel shelf. I think I made a mistake by installing a 6 x 9 instead of a subwoofer.
    I initially convinced myself that I don't need a subwoofer because I listen to music pretty normal not loud. I am happy with it but not fully satisfied because at low levels I don't hear a bass or a thump.
    NOW.....I want to change the front to decent splits, change the rear door speakers to decent ones and add a subwoofer plus necessary amps. I want to use the 6 x 9 still with the subwoofer because it's a waste to kill them.
    Is it okay to run all (front, rear door, 6 x 9, plus a subwoofer).
    Also is it possible to mount the subwoofer in the middle parcel shelf in between the 6 x 9? WOuld cutting the middle part weaken the structure? I was thinking 1 x 8 inch or ten inch (if it fits) for the little extra thump.
    Please advice because I am getting confused....thanks.
    sxc_sound's Avatar
    sxc_sound is offline getting Kustom
    VT Series 2 S pak
    May 2008
    Parkdale
    shouldnt this be in the car audio section :S
    Anyway... Running 6x9s is kinda pointless when having a sub as well. 6x9s are meant to be a sub replacement, it would be better if you had:
    High quality 6" splits in the front
    6" in the rear doors
    then get a 8" or 10" sub
    and a 5 channel amp
    And about putting a sub in the back shelf, it is illegal to cut any holes in the back shelf, and yes it would weaken it, id suggest if you want to save space, mount the amp between the speaker holes on the back shelf and get a 10" sub in a box and sit it at the back of the boot. Thats IMO anyway.
    666vt's Avatar
    666vt is offline [ no style ]
    vt executive 3.8
    Mar 2007
    nsw
    Quote Originally Posted by sxc_sound View Post
    and a 5 channel amp
    my vt doesnt have holes in the rear parcel shelf, there arent any speakers there and im planning on putting my pioneer 6x9's in there, but i will have to cut it out, will this be illegal?
    my ride [ vt - no style ]
    Apr 2008
    I should really read the OP, not just the posts after it
    VT Acclaim
    Oct 2008
    o... sorry for posting here, I just went straight to VT related stuff not realising there is a car audio forum....
    Anyway thanks for your replies....
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    Quote Originally Posted by 666vt View Post
    Cutting the metal is illegal yes and not something you want to be picked up on in an RWC as its pretty hard to undo.
    Ve Calais V 6ltr
    Sep 2007
    ADELAIDE
    Quote Originally Posted by 1991_Vn2nV View Post
    they are there already there are just 3 small spot welds holding the plate in. just a small tap and the plate will drop out and just slide the speaker in. i installed some on a series 1 vt executive, so if the base model has it all the rest of the vt range should have it
    sxc_sound's Avatar
    VT Series 2 S pak
    May 2008
    Parkdale
    yeah on the rear shelf there are already 6x9 holes, you just have to knock out tthe spot welds, i used a hammer and nail punch. You might have to drill holes for the bolts that hold the speaker down tho...
    dijm8's Avatar
    dijm8 is offline What You Looking At
    VZ SS LS3
    Jun 2006
    666vt's Avatar
    vt executive 3.8
    Mar 2007
    nsw
    ahhh thanks guys... sorry for the major thread hijacking too =[
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Some models, like Statesman etc, come already fitted with 6x9's in the parcel shelf, so I don't see any problems with it being legal.
    MY RIDE
    Apr 2008
    Some cars don't come with airbags, but it's illegal to remove them from ones that do
    If the plates are tack welded in you should be fine to remove them, but if you have to physically cut holes then it is modifying the structure of the car.
  1. H/U RCA plug confusion
    By Brycestro in forum Car Audio
    Last Post: 14-03-2006, 11:19 PM
  2. Vy/vz Ute Confusion
    By vsbakkie in forum VY Holden Commodore (2002 - 2004)
    Last Post: 06-12-2005, 01:25 AM
  3. VL air cond confusion
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 05-09-2005, 09:13 AM
  4. A Matter Of Confusion
    By freckly in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-12-2003, 03:14 PM
