Results 1 to 5 of 5
Thread: removing door loom vt exec
    vt
    Oct 2008
    Default removing door loom vt exec
    hey folks
    just wondering how do i remove the loom in the doors ? their is a clip but their's no way to disconnect it, its mounted behind the seat belt pulley.
    i plan on putting the loom for electric doors and mirrors anyway so could i just cut it seeing a new loom will be put in ?
    cheers
    SMIT's Avatar
    SMIT is offline Donating Member
    VT C2R TURBO 5SP + CRUNCH VE SSV 6SP
    Aug 2005
    Mornington Peninsula, Victoria
    i don't see where you mean the seat belt pulley is. Anyway, what do you mean by electric door? pop locks? and for the mirrors if you don't already have them, i don't know seeing as every model came out with them?
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by macksvt View Post
    hey folks
    cheers
    I wouldn't cut it because they just unplug. Is it a series 1 or series 2, because the looms are different for each?
    MY RIDE
    vt
    Oct 2008
    its a 1997 vt exec.
    i want to put my 1998 s pack doors which have the elcetric windows.
    are the looms different ?
    cheers
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    its a 1997 vt exec.
    cheers
    The looms should be the same. The difference between series 1 and 2 looms is they way they plug into the body. They plugs on series one can be difficult to disconnect and may require a bit force. It's like they are stuck together. The series 2 has a different design where the connector is not connected to the actual body of the car.
    MY RIDE
  1. Removing wiring loom
    By joebloggs in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-07-2008, 08:00 AM
  2. pics of calias door loom tubing
    By SweetWagon in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-03-2007, 03:46 PM
  3. Removing Blinking Security LED from VR Exec...
    By ozzietj in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-07-2006, 04:26 PM
  4. Drivers side Rear door wiring loom
    By totality in forum Electrical Wiring / Questions
    Last Post: 26-05-2006, 06:47 PM
  5. VN Exec wiring loom.... Help!!!!
    By stockVN in forum Electrical Wiring / Questions
    Last Post: 12-05-2005, 05:27 PM
