Page 1 of 2 12 LastLast
Results 1 to 25 of 31
Thread: King Springs VX SS
    BA XR6T, VG S Pack
    Jan 2006
    SA
    Default King Springs VX SS
    Going to put my 19" GTS rims on my VX SS tommorrow and want to lower it, but don't want to go stupid like I have on my previous cars. I want to be able to get over speed bumps and spoon drains and stuff.
    Mainly looking at the rear at the moment, what sort of spring should I be looking at, superlows, ultra lows?
    Pretty much want it to look a bit lowered but not like a slammed car.
    Any one have any pics of useable height lowered IRS VT+ model cars?
    Ozzie's Avatar
    Ozzie is offline JCCC Warrnambool
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    check mine out, its now on superlows.
    ultra lows would be a bit slammed.
    superlow is low but still legal. (keeping in mind the suspension travel)
    Full Spectrum's Avatar
    Full Spectrum is offline Customize your life.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    Have a cap cook at mine also. It's lower at the front then the rear. I haven't rubbed it anywhere yet.
    Quote Originally Posted by Yoda
    Do, or do not. There is no 'try'.
    <img src=http://forums.justcommodores.com.au/signaturepics/sigpic440_66.gif border=0 alt= />
    BA XR6T, VG S Pack
    Jan 2006
    SA
    bpottz's Avatar
    bpottz is offline Whipped By SAPOL
    VT Berlina
    Aug 2008
    South Oz
    mines on pedders i think but they are the equivalent of superlows, its low, but not slammed. only time it ever scrapes is if i have a full load.
    ultra lows would be scraping over gum nuts mate.
    My VT Berlina [LIONLW] - Lowered, 18's, Leather
    http://forums.justcommodores.com.au/...tml#post863216
    Voodoo VE SS UTE
    Feb 2007
    i Have king spring super super lows in mine and it scraps the cats against everything and thats with 15mm spacers between the spring and where it sits against the body. if you want it useable super lows are probebly low enough
    2000 VX Calais 3.8L Supercharged
    Jul 2006
    ive got superlows in front, and ultra lows in the rear, ill get a pic tomorrow
    fronts sit about 620mm from top of wheel arch to ground, and rears about 590 from top to ground. lowest part of the car would be the exhaust inbetween middle and rear mufflers about 100mm~
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    Mine are selby which are made by kings..
    Just measured my height and it's 65cm high ground to wheel arch front and back The same.
    So that's 650mm front and rear.. That's not lows That's closer to superlows.
    And yet the rear sits high.
    3.8L GT35 4runner/VK calais
    Dec 2006
    Nowra
    VXSS super lows all round
    doesnt scrap if you a careful
    the exhaust is a bit low where it goes under the diff
    but it has twin 3" on it
    cheers GM
    Jul 2006
    super low front, ultra low rears, factory 16's
    doesnt scrape if you go slow enough over bumps, only on driveways/carpark ramps ect if theyre steep
    http://members.optushome.com.au/don0xer/slul.JPG
    Ozzie's Avatar
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    Quote Originally Posted by don0xer View Post
    So yours sits on factory 16"??...
    Mine does to, And i was wondering what height springs i have. @ 650mm front and back would that scrap in for superlows?. Lows are much higher right?.
    This pic might make it look lower, As it had 75 liters in it's belly and about 25kg of shopping.
    Jul 2006
    well according to kingsprings latest catalogue, lows will drop it to around fe2(20mm lower than standard), superlow's another 20mm below that, and ultra lows another 20mm below that. i cant give u exact measurements of what i had before hand as my shocks were fked and only gave me about 40mm drop on the rears lol
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    Thanks for that mate.. It's leaning towards SL.. I do want SSL or ultra rears. Way to high up the bum. And i like the way yours sits.
  15. #15
    GMM CAMMED and STALLED VT SS 5.7
    Sep 2007
    Melton,Victoria
  16. #16
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    When you go with the bigger rims, Does it lower it more?. Because i was always thinking if i had SSL back with 19" it would lift the bum. But does it work in reverse?.
  17. #17
    Ozzie's Avatar
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    The bigger the rim (20"say) it will fit more snug under the gaurds.
    Doesnt really effect the hight of the vehicle though.
    But say 18" which is the same as say 15" in overall diametre it will raise the car slightly. Not much that its noticable
  18. #18
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    Cool thanks, IS that why some raise their cars with 19" rims because they sit to far under the arch?.
  19. #19
    adamc11 is offline Donating Member
    VY SS
    Feb 2008
    E. & W. Suburbs Melbourne
    You cannot raise your car by putting on bigger or smaller wheels. Okay i lied. You can BUT to keep your speedo the same and to keep it legal the overall diameter of your rim+tyre combination has to be the same. SO if i whack on bigger profile tyres onto my current 18's, it will raise it, but then my speedo will be out and it won't be legal. So if you up the size of your rim, you down the profile of your tyre to keep the diameter the same. Therefore it should have no effect on the height of your car. So essentially you can only go so big, before the tyre you require is too low a profile which doesn't exist.
  20. #20
    VY SS
    Feb 2008
    Quote Originally Posted by SlickHolden View Post
    I assume when you refer to SSL you actually mean UltraLow? As kings only have SL and UL. I would go SL all around, UL will be too low. Have a look here: King Springs refers to V8's but i figure the amount it lowers your car should be the same.
  21. #21
    B£å¢kÐðg's Avatar
    B£å¢kÐðg is offline D.I.L.L.I.G.A.F
    VY Commodore
    Oct 2005
    Quote Originally Posted by adamc11 View Post
    To my knowledge kings also have springs which aren't listed, I have KHRL-SSSL's in the rear of mine which are incredibly low but aren't listed in the superlow/ultralow catalogue, most people I know didn't even know they existed until they seen mine.
    "Some say that he only knows 2 facts about ducks...and they are both wrong".
    Every K Over Is A Thriller
  22. #22
    bpottz's Avatar
    VT Berlina
    Aug 2008
    South Oz
    Quote Originally Posted by B£å¢kÐðg View Post
    got any pics mate?
  23. #23
    bpottz's Avatar
    VT Berlina
    Aug 2008
    South Oz
    heres a pic of my pedders (equivalent of SL's i think) from a cruise last night
    this is with a full car load + half a tank of gas + quarter tank of petrol
    its on 18's
    (i wasnt even booting it at the time, it squats down even further when i do)
  24. #24
    VY SS
    Feb 2008
    bpotzz lol i would say thats an equivalent Ultra Low king spring... maybe even lower... looks pretty damn low if it isn't squatting that is...
  25. #25
    vnv8driver is offline Banned
    304 Calais
    Aug 2007
    Up your mum
    go for a standard heavy duty low and it will lower your car by 30mm, superlows lower by around 35-40mm (realistically) and ultra lows are around the 50-60mm mark.
    If you want to lower your car just that little bit (FE2 equivelant) then go a standard heavy duty low for your model car.
    Send us a pm if you want a discount on new springs/shocks
  1. King springs?
    By gupatrol in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-11-2011, 11:16 AM
  2. FS: Whole Suspension Setup (Springs , Shocks, Struts) King Springs
    By ssmate in forum Parts And Other Items For Sale
    Last Post: 01-11-2007, 06:24 PM
  3. VN non IRS low king springs
    By timmy_tam in forum Parts And Other Items For Sale
    Last Post: 13-04-2007, 12:02 AM
  4. Fs: [vic] King Springs For Vs Irs
    By georgeonboost in forum Parts And Other Items For Sale
    Last Post: 03-03-2007, 05:35 PM
  5. King Springs??
    By VZGEN4 in forum General
    Last Post: 04-06-2006, 09:48 PM
