Results 1 to 5 of 5
Thread: VX key problem
    Vx Executive
    Nov 2008
    Default VX key problem
    I have a problem with my VX commordore where i put the key into the barrel but it will not turn and so therfore i cannot start the car. Had to get the RACV to start it. They seemed to say i may need a new barrel or mech.
    Can anyy one give me any idea what might be wrong with it and a idea of who can fix it, ie can my local mech fix it or do i need to go to a dealer? any idea on price also ?
    Ozzie's Avatar
    Ozzie is offline JCCC Warrnambool
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    the pins inside the barrel may be worn.
    you can try lubing inside the barrel to see if that helps
    Vx Executive
    Nov 2008
    commsirac is offline Banned
    vx
    Aug 2007
    probably pins worn out etc. Do you have more than one key. I recently got a new key made for my vx and great trouble turning the barrel. Got the old key put into the new remote unit and it works a lot more freely, the locksmiths were adamant that the key had been cut to the correct specs and that it was a problem with wear inside the lock( I did explain to them that I wanted a copy of the key I had.......not what of what it may have used to be like!!!!)
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Quote Originally Posted by Chunky View Post
    Thanks, should i use RP7 or something like that ?
    You should use graphite powder for locks - although it's a bit messy and hard to get in. RP7 and similar products attract dust.
  1. vent problem and horn problem
    By plasmid2 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-06-2008, 10:53 PM
  2. VY A/C Problem
    By thehotline in forum VY Holden Commodore (2002 - 2004)
    Last Post: 30-01-2008, 09:02 PM
  3. Pt 2 cold starting problem - Is my ECU the problem??
    By manfred in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2007, 09:56 PM
  4. Problem......
    By beetle81 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-11-2006, 07:34 AM
  5. problem
    By pandacav in forum V6 Development And Modification
    Last Post: 21-04-2006, 07:48 AM
