Results 1 to 12 of 12
Thread: Air Con Help?!?
    fitz_vt's Avatar
    fitz_vt is offline Pass Me A Wrench.....
    VT Commodore SII Olympic Edition
    Nov 2008
    Adelaide - South Side
    Default Air Con Help?!?
    got a quick question to anyone thats had this problem, my VT's air con works but it takes a while to kick in and its not get cold... i think i may need a recharge or service, any idea's people.....??
    vt berlina series 1
    Sep 2008
    might just be a little low on gas , take it to a a/c guy and he can put a machine on it and tell you pretty much straight away
    fitz_vt's Avatar
    Nov 2008
    thanks banga, booked it in for 2moro
    |VT Olympic Edition 3.8L Ecotec | VY S Pack Green Interior|
    Mods to come | VY Map Reading light/Sunnies Holder|
    "Give me a minute, I'm good. Give me an hour, I'm great. Give me six months, I'm unbeatable."
    vt commador
    Nov 2008
    Mate i found with my VT that if the oil level in the air con compressor is not exact the air con plays up badly. mine costs me over $1200 to fined that out!!! costly venture that was
    Full Spectrum's Avatar
    Full Spectrum is offline Customize your life.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    And yet they claim you wont need to gas it for the time you have the car ?.
    I had to have mine refilled and a trickle of oil added just encase, Cost a bit that little trickle.
    Quote Originally Posted by Yoda
    Do, or do not. There is no 'try'.
    <img src=http://forums.justcommodores.com.au/signaturepics/sigpic440_66.gif border=0 alt= />
    fitz_vt's Avatar
    Nov 2008
    Hey guys went to my local aircon expert,
    1. my fan motor relay was shot up?!? replaced $16.50
    2. Aircon Regas and Service $150 (incl recv and dryer)
    3. New O rings for my compressor $100
    Very expensive journey but now i have a different problem on my VT.
    he says that my air conditioner motor needs replacing because every time i put my a/c on HI fan, it cuts out everynow and then, i know i dont have climate control... HA..... aparently its a "common fault", it needs an extra fuse or something i think its a load of crap but yeah if anyone can tell me different.... it would be greatly appreciated.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    Mate stick your head under the bonnet and see if you have both "high" and "low" Relay switches there.
    If you only have one it will do that. I had one and it would come on and off.
    vt berlina series 1
    Sep 2008
    mine does that it cuts out when it gets to a certain temp then kicks in again after a while , try asking another ac guy or try the electrical forum ?
    Brucefromruse is offline CRAVEN MOORHEAD
    VS executive s2
    Oct 2007
    Campbelltown nsw
    zzzzzzzzzzzzzzzzzzz
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    I spoke to a guy from holden about this, They say when sitting the fan should be on with a/c on. When you drive off it will cut off as speeds increase. And do the same in reverse when dropping speeds. It should not work like the fans when the car gets to hot.
    fitz_vt's Avatar
    Nov 2008
    Quote Originally Posted by Brucefromruse View Post
    Just get a service,or better still put the window down and a stop using all this excess fuel and save the planet.
    it would be nice if u looked at the threads i have posted..... HELLO
    Quote Originally Posted by fitz_vt View Post
    vlv8vic's Avatar
    vlv8vic is offline <---Brad Quaid = internet stalker
    M5
    Mar 2005
    Australia
    Less fuel used running the ac than you'd use having the windows down. Welcome to beyond the 90s.
