Results 1 to 6 of 6
Thread: Advice for a long trip
    VUII SS
    Mar 2008
    Default Advice for a long trip
    Over the Christmas holidays I will be taking the car on a fairly long trip (Sydney to Byron and back), and I was wondering whether anyone could suggest anything I should do to the car in preparation??
    Its last service was in Aug and its next one isn't normally due til Feb next year but I think I may get it serviced before I go away as a precaution??
    Any advice would be appreciated.
    Cheers.
    Cursed CX8 is offline Banned
    VY Adventra
    Feb 2008
    Walking distance to FG meets
    how many kms since the last service? if its stuff all then possibly just check the oil and coolant, top up if needed etc. I always carry radiator clumps and a knife for hacking radiator hose a set of fuses and a couple of headlight globes.
    One thing i always find i use is a set of jumper-leads. On every trip there is always a stranded less in a hyundai to rescue
    if its getting close to the service interval get it done, check the brakes etc.
    WJD634's Avatar
    WJD634 is offline WJD634
    VT Executive
    Feb 2008
    Port Pirie
    it should be fine just check trans, power steering fluids, oil, coolant and top up wats needed. take the trip easy and keep checking ya temp gauge. maybe stop off for a half hour every few hours to keep the temp down and most importantly give u a rest. I've driven mine from adelaide to melbourne and back with no problems, just keep essentials in the car and be sensible have a good trip matey!
    VT Series 1 V6
    Jan 2008
    I've driven my VT over 100,000kms in the last 5 years, mostly Canberra-Newcastle and return plus several trips around country NSW hauling a full trailer, not a single problem, not even a flat tyre. Just make sure your spare is good and pack a tool kit. Like the others said, check all your fluids and tyre pressure, check your belt tension and all your lights/turn signals (maybe pack a few spare bulbs) and take it easy and enjoy the trip. I hope you have cruise control.
    VX Calais 01 3.8lt Ecotec
    Jul 2006
    Check you tyres, brakes and fluid. Do an oil and filter change, clean the air filter, especially for dusty roads etc. Most importantly check your coolant and hoses. Take a spare Radiator cap as well, small tools and strong tape (quick patch for hoses). Also pack a torch, small hydrant and some drinking water. Serious. Oneday when your cars a beast and you do track work, you will need the hydrant any way.
    pablo is offline Donating member
    Was a 1997 vt v6 wagon
    May 2006
    When you check the tires, put a few extra pounds in, I run my standard 15" stock tires at 34-35 lbs on a long trip, as recommended by the Bridgestone tire mob. Better economy with more even wear across the tread.
    Also, take a chamois with a bottle of water to get rid of any bugs that you will have splattered on the screen.
    Pablo
  1. how long is too long to wait?
    By Troy711 in forum The Pub
    Last Post: 03-06-2008, 05:16 PM
  2. Should i? (Long Trip)
    By defyet in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-01-2007, 07:11 PM
  3. Results of fuel economy on long trip.
    By Wombat in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-07-2006, 08:08 PM
  4. Vt long trip
    By vt_lover in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-03-2006, 01:50 AM
  5. Pre Long trip checklist
    By MarzVP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-09-2005, 01:57 PM
