Results 1 to 8 of 8
Thread: interior/boot lights not working
    vs II exec
    Jul 2008
    Default interior/boot lights not working
    hey guys
    just a quick question, well a few days ago, my interior light (the on on the roof) and my boot light stopped working at the same time. So obviously they run off the same circuit, and im thinking it would have blown a fuse, would this be right? or what would u suggest? and also where are the fuses located? id imagine under the steering wheel panel
    cheers guys
    Smith
    VT Exec SII
    Jan 2008
    Yeh sounds like a fuse, just undo the panel under the steering wheel. should just need to replace the 10 amp fuse. use the map to find where it is
    sxc_sound's Avatar
    sxc_sound is offline getting Kustom
    VT Series 2 S pak
    May 2008
    Parkdale
    Mc Nugget's Avatar
    Mc Nugget is offline Aka ShiZzl3
    VX II - LOWERED - 19's - HID's...!
    Jun 2008
    Melb, SE Suburbs
    i had mine blow on me the other day, but that was my fault trying to hook up neons to power when door opens.
    sxc_sound's Avatar
    VT Series 2 S pak
    May 2008
    Parkdale
    i had the same problem, iv got 12 sound reactive LED's, 2 x 30cm neons, 22" neon attached to it, i just upped the fuse to a 15 amp instead of 10, works a treat, and is all still protected
    vs II exec
    Jul 2008
    VX Commodore Lumina
    Jan 2006
    South Adelaide
    Quote Originally Posted by sxc_sound View Post
    Isn't the fuse there to protect the wire that's providing power to the circuit? So upping the fuse could potentially cause damage to the wire that provides power from the battery to that fuse.. I don't know a huge deal about car electronics, but in general I know this is the case. You'll have to be care full before adding a much larger fuse, as the power wire supplying the power won't be protected, and if it isn't able to carry that amount of current, it will catch on fire.. Correct me if I'm wrong.
    MY10 SSV UTE
    Dec 2006
    Melb
    Default ..
    yeh fuse had the same prob not long ago.
    no interior light, no glove box light and no boot light
  1. Interior Fan Not Working
    By mum with VT in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-01-2009, 07:15 PM
  2. Both my tail lights and brake lights have stopped working.
    By stuballs in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-06-2008, 11:35 PM
  3. All Interior Lights stop Working When Headlights turned on
    By GMTANK in forum Electrical Wiring / Questions
    Last Post: 30-08-2007, 11:24 AM
  4. No interior lights, dash lights or elec windows vk
    By ported in forum Electrical Wiring / Questions
    Last Post: 18-09-2006, 05:10 AM
  5. VS Interior Fan not working
    By 1996vsman in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-03-2006, 09:34 PM
