Results 1 to 12 of 12
Thread: RPM problem
    2001 VX
    Nov 2008
    Default RPM problem
    Hi to Everyone
    I have a major problem with a taco reading. We removed the fuel injection system and installed a carb with a MSD system. Now we cannot get the tacho working. When I take the Yellow wire from a 6010 MSD unit and connect it to the brown wire the tacho works but gives a reading of 6000 rpm instead of 3000 rpm. I have tried using a MSD 8913 taco driver and take the signal from the + of the coil
    the reading is true. BUT it will now only register to 4500 RPM and needle is very shaky app 150 RMP either way has anybody had this same problem and how would I be able to solve this.
    Please can you help
    fitz_vt's Avatar
    fitz_vt is offline Pass Me A Wrench.....
    VT Commodore SII Olympic Edition
    Nov 2008
    Adelaide - South Side
    as long as you can get an accurate reading to 4500 RPM that shouldnt matter unless your planning on thrashing your VT?? but i can understand you wanting a better reading from your tacho, try hooking the brown wire up to the MSD 8913, that might work but i will have a look at the wiring diagrams and get back to you.
    |VT Olympic Edition 3.8L Ecotec | VY S Pack Green Interior|
    Mods to come | VY Map Reading light/Sunnies Holder|
    "Give me a minute, I'm good. Give me an hour, I'm great. Give me six months, I'm unbeatable."
    Jesterarts's Avatar
    Jesterarts is offline Your freedom ends where mine begins
    2005 HSV Z R8 Manual
    Nov 2005
    Mornington, VIC
    Hang on wait... you installed a carburetor on an ecotec?
    Not sure on the tacho thing... good luck with it though...
    fitz_vt's Avatar
    Nov 2008
    there shouldnt be any problems but i think its with your unit, take it back and get a new unit that may solve the problem...
    nice work putting a carby in a VT..... would of been hard work.
    Jesterarts's Avatar
    Nov 2005
    Mornington, VIC
    Ok... just going to show my lack of knowledge in the field now.
    What are the benefits or reason that would motivate someone to put a carby on an engine that has fuel injection?
    fitz_vt's Avatar
    Nov 2008
    Quote Originally Posted by Jesterarts View Post
    its actually a really good question....
    i always thought that fuel injected is better then carby its more precise but with a carby it might sound nicer......
    TUF UTE's Avatar
    TUF UTE is offline Dave
    05 VZ SENATOR
    Nov 2008
    adelaide
    im planning on running msd, double pumper and bug catcher on my Vs 304 for tuning ability and more simple setup.
    SIR LS1
    the two ton go kart
    2001 VX
    Nov 2008
    Hi to all
    We put the carb system on the car as there was a lot of mods done to the car and then nobody could tune it properly. We used a Edelbrock rpm and a 650 holley carb hp increased app 60 HP Torque app 100 ft/lbs. Please reffer to edelbrocks web for more details or gm performance website. A bit more fuel is used but worth it for the Add HP we rev at app 6500 rpm and need rev counter. This unit is actually a 408.
    Thanks
    social's Avatar
    social is offline Ute Finatic
    MY06 6.0L VZ Thunder(na naa na naa..)
    Nov 2008
    South Aus
    Have you got the setting on the back of the tacho set to 6 or 8 cyl (w/e ur cars engine is) lol sometimes its the most obvious things...gd luk
    Quote Originally Posted by Shooter03 View Post
    Washed it and now the wife's gonna take it out and get it dirty.
    Quote Originally Posted by QldKev View Post
    You are talking about the car?
    2001 VX
    Nov 2008
    howepower's Avatar
    howepower is offline Donating Member
    vc commodore sl
    Nov 2008
    KIELOR DOWNS
    yea had the same problem on gen 3 on carb the earth needed to be grounded twice seperately and i i hard mounted the box no more issues
    howepower's Avatar
    vc commodore sl
    Nov 2008
    KIELOR DOWNS
    i have anothr 6010 for sale too
  1. vent problem and horn problem
    By plasmid2 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-06-2008, 10:53 PM
  2. Pt 2 cold starting problem - Is my ECU the problem??
    By manfred in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2007, 09:56 PM
  3. VT Air Con Problem
    By Harvs82 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-12-2006, 05:17 PM
  4. Anybody had this problem?? (Help...)
    By sheldo86 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-10-2005, 01:46 AM
  5. has anyone had this problem??
    By boxhead in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-07-2005, 07:09 PM
