Results 1 to 6 of 6
Thread: VU SS Diff into VY Exec
    nicko451's Avatar
    nicko451 is offline Nicko
    VY Executive V6 5Spd
    Sep 2005
    Default VU SS Diff into VY Exec
    Im gettiing given the center out of my brother inlaws VU SS Ute and was just wondering if or what i have to do to get it to fit in?
    Cheers guys!
    fitz_vt's Avatar
    fitz_vt is offline Pass Me A Wrench.....
    VT Commodore SII Olympic Edition
    Nov 2008
    Adelaide - South Side
    the simplest way to get it to fit is to get a V8.... you shouldn't have many problems but because your VY is an V6 ECOTEC and the VU SS ute is a V8 the gear ratio's arent gonna be good for your engine but give it a shot, it should be the same as chaning the gear box if you have ever done that
    if not take it to a mechanic who will probably charge you alot to do it but atleast u know the jobs done.
    |VT Olympic Edition 3.8L Ecotec | VY S Pack Green Interior|
    Mods to come | VY Map Reading light/Sunnies Holder|
    "Give me a minute, I'm good. Give me an hour, I'm great. Give me six months, I'm unbeatable."
    nicko451's Avatar
    Sep 2005
    its 3.46 which im almost postive is ok!
    im wondering if its compatible, i know its like changing a transmission was just wondering if the VX Diff fists the VY!!
    VY SII HBD Calais L67
    Dec 2006
    Yeah it will bolt straight up. I have a 3.46 from a VXII S (L67) which is now in my VY L67 Calais. The diff housing is larger than a N/A V6 but all the bolt up points are identical. Just make sure the new diff has a housing for the wheel speed sensors.
    I had the ppk value in the ECU changed to 6791ppk to calibrate the speedo. With an auto it now revs @ 2000rpm on 100km/h. Good kick from it too off the line. Might as well upgrade the rear sway bar while you're at it because the cradle has to come down and it helps to undo the sway too.
    nicko451's Avatar
    Sep 2005
    fitz_vt's Avatar
    Nov 2008
    Quote Originally Posted by nicko451 View Post
    ok cheers! Also is the VT LSD (out of L67 - 3.07) the same as the VX??
    yes it is... ( i think) i only have a vt so i am just taking a stab in the dark most things from the vt are the same as the vx
  1. diff making a noise / replacing diff
    By yipya in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-12-2008, 11:30 PM
  2. vs exec s1 vr exec s2 similarities?? help
    By joshooaahh in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-08-2008, 11:05 PM
  3. Vp wagon Exec Diff prices
    By vp manual wagon in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-06-2006, 06:23 PM
  4. VL Exec Diff and Brake Upgrade
    By hyjinx in forum VL Holden Commodore (1986 - 1988)
    Last Post: 06-12-2005, 06:35 PM
  5. VP Exec. Diff
    By tr3nt in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-03-2005, 07:46 PM
