Results 1 to 7 of 7
Thread: VU SS Help
    VN BT1 - 5.0
    Apr 2005
    Perth, W.A
    Exclamation VU SS Help
    Hi,
    Just purchase a VU SS, the engine light has been on ever since i've picked it up, how can i check what the light is on for? i believe in the newer models it's not as simple as bridging the line and counting the flashes...
    the other thing is the oil light and beep goes off every now and then... plenty of oil and it's just been serviced... there's no pattern to it, but a few times its happened when braking and turning....?
    Any help would be appreciated.
    Cheers,
    Alex
    Rolling in a 5.0
    MY10 SSV UTE
    Dec 2006
    Melb
    Default ...
    the oil light doesnt mean low oil, its low or no oil pressure.
    take it to holden or a workshop with a tech2.
    engine light could be on coz your oil pressure switch has failed.
    have read that ppl's engine's have turned to **** real quick due to no oil pressure.
    on the other hand mate has a vs which has had the engine light on for the last 2 years.
    but diff engine's will do diff things.
    VN BT1 - 5.0
    Apr 2005
    Perth, W.A
    yeah i figured the flashing was just low pressure, after the low revs and then the steering pump going would reduce pressure, as for the light, i'm thinking it's something to do with that. or the computer has been chipped and not reset or something maybe?
    Rolling in a 5.0
    MY10 SSV UTE
    Dec 2006
    Melb
    Default ..
    engine light covers the senors etc
    get it checked by a tech2 scanner and it will tell you exactly whats gone wrong instead of playing the guessing game and replacing parts that arent at fault.
    good luck
    VN BT1 - 5.0
    Apr 2005
    Perth, W.A
    cheers, yeah i'll take it to the dealer that i got it from and get them to tell me... they should've fixed it anyways.
    Rolling in a 5.0
    fitz_vt's Avatar
    fitz_vt is offline Pass Me A Wrench.....
    VT Commodore SII Olympic Edition
    Nov 2008
    Adelaide - South Side
    yeah sounds like your bcm or your engine sensors and oil pressure is whacked out....
    |VT Olympic Edition 3.8L Ecotec | VY S Pack Green Interior|
    Mods to come | VY Map Reading light/Sunnies Holder|
    "Give me a minute, I'm good. Give me an hour, I'm great. Give me six months, I'm unbeatable."
    VN BT1 - 5.0
    Apr 2005
    Perth, W.A
    that's what i figured, i might post a pic... what's the sensor at the front right of the engine (if looking at it from the front) there's some creative wiring that has been done on that! i'm thinking if the wiring there is dodge it could be causing some probs
    Rolling in a 5.0
