Register - Members List - Calendar - Mark Forums Read -
Go Back   Just Commodores > Holden Commodore Related > VT - VX Holden Commodore (1997 - 2002)
VT - VX Holden Commodore (1997 - 2002) Talk about anything relating to the VT - VX Holden Commodore.
Reply
LinkBack Thread Tools Display Modes
  #26
Old 13-11-2008, 11:37 PM
Ozzie's Avatar
JC Member
Ride: VT Executive V6
Ozzie Calais
Quote:
Originally Posted by pablo View Post
greenac, I have a tube of 'kopr-cote', I have had for years, made by AMPOL. It is good for over 800 deg,C. Way over the engine temp. Used it on manifold studs, nuts and exhaust joins and clamps, as well as spark plugs in iron and aluminium heads, bikes and cars. Never had any problem using it.
Pablo
isnt that just anti-cease? or does it penatrate?
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Google Bookmark this Post!Yahoo Bookmark this Post!Bookmark to AskJeeves!Bookmark to Slashdot!Live Bookmark this Post!Spurl this Post!Reddit! Wong this Post!
  #27
Old 14-11-2008, 07:51 AM
Ride: VX Calais 01 3.8lt Ecotec
Trade Rating: (0)
vxcalais_01 Executive
Quote:
You can get the Permatex sachets from Supercheap especially for the spark plugs. Just get that. Innox to penetrate....
  #28
Old 14-11-2008, 09:13 AM
Ride: 2007 SVZ Wagon
Trade Rating: (0)
Benboy Berlina
Yeah fitz_vt, 5 not 7 ! I was never any good at addin' an' subtraction!LOL
You could try a 'rattle gun' to shock it loose?
As I have said before, plugs should ALWAYS have the threads lubricated with anti-sieze grease before they are screwed in. Then tightened to 15-25 nm, if you don,t have a torque wrench, screw them in until the gasket just touches the head, then turn them a further 30deg. NO MORE! ..they DON'T have to be very tight, only enough for the gasket to seal.
All the problems I have had with plugs have apparently been caused be the "mechanic" overtightening them with dry threads. If the head is aluminium, the problem escalates to the bloody thread easily tearing.
Pablo
I don't agree with comment re applying anti-seize to spark plug threads neither does manufacturer. Problems with 'tight/stuck' spark plugs result from over tightening. If you read manufacturers instructions on packet it is impossible to get it wrong.
p.s. just in case you might be left handed, make sure that you are applying pressure in the correct direction to undo plugs. That should be anti-clockwise.
  #29
Old 14-11-2008, 04:33 PM
fitz_vt's Avatar
Air Horns Are Great.....
Ride: VT Commodore SII Olympic Edition
fitz_vt Executive
nah mate right handed... it budged, and is slowly undoing just taking it step at a a time.... (i think i may need to re thread)
__________________
VT Olympic Edition 3.8L V6 ECOTEC - Midnight Blue - Fully Stock
Quote:
Originally Posted by andyman View Post
if in doubt go to a mechanic
MY RIDE yes its fully stock
  #30
Old 18-11-2008, 12:33 PM
fitz_vt's Avatar
fitz_vt Executive
YAY!!!! finally got it out, now have champion golds in my car Yay
__________________
  #31
Old 18-11-2008, 12:35 PM
Ozzie's Avatar
JC Member
Ozzie Calais
Quote:
Good news mate. I take it you never had to re-thread?
  #32
Old 18-11-2008, 08:14 PM
fitz_vt's Avatar
fitz_vt Executive
nope no rethread needed a bit of wd-40 and a but if elbow grease with a new socket wrench did the trick
__________________
  #33
Old 20-11-2008, 09:17 PM
ozengines's Avatar
Ride: VX II SS Ex Chaser V8
Trade Rating: (0)
ozengines Executive
The problem with Copper is that it is a high valence metal, so it will dillute a significant lesser valence metal, within time it will weaken the structure of the thread, and you will one day, pull out pieces of the thread with your plug
Its called Galvanic Corrosion
Copper should only be used on metal to metal threads like the header studs, were there is contact with aluminium steer away from copper, use aluminium anti seize or graphite based.
Beware of grease based things or oil on your sparkplug, every time there will be al thin layer of "ceramics" baked on the thread, and the plug will go more unwillingly (the same thing you see as a brown to black enamel on the underside of your pistons).
  #34
Old 20-11-2008, 11:15 PM
Ride: 1997 vt v6 wagon
Trade Rating: (0)
pablo Executive
Thanks for that ozengines, that is very interesting reading about all these scientific technical observations. Just wondering, how long would it take before the thread would be ruined by using a copper base anti-seize on the plugs in
A/ Aluminium head
or
B/ Cast iron head
Pablo
  #35
Old 22-11-2008, 05:01 PM
fitz_vt's Avatar
fitz_vt Executive
PS my holden has a cast iron head not an aluminum head
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Spark Plugs DanoSS LS1/2 Development and Modification 24 01-03-2007 07:29 PM
Bosch Platinum Spark Plugs or NGK Irridium Spark Plugs RVN 355 The Pub 21 05-05-2006 05:38 PM
Spark plugs in 5lt Panelvan1975 V8 Development and Modification 18 27-02-2006 02:30 PM
Spark Plugs. spd_dmn VB - VK Holden Commodore (1978 - 1985) 5 18-12-2005 10:46 AM
Spark Plug Leads Getting 'baked' on to Spark Plugs? holden#1 VR - VS Holden Commodore (1993 - 1997) 2 04-09-2005 03:16 PM
Remortgages | Secured Loans | Cheap Moissanite Earrings | Personal Loans | McDonalds | Car Reviews
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
1 2 3 4 5 6 7 8 9 10
