Results 1 to 4 of 4
Thread: having probs with my 97 VT Executive commo.
    98 VT Executive
    Aug 2008
    Sunshine Coast
    Question having probs with my 97 VT Executive commo.
    G'day guys and gals.
    i got a 97 VT v6 executive commodore. And it has been great so far for me but i have just came across a few small issues, as listed below.
    1: Shaking alot
    When im idling the car, as if im waiting at the lights etc, it shakes a lot, always the front passenger will ask me why is it happening, because i think they can feel it the most. It really doesn't bother me, but i know that it mechanically shouldn't be happening. I did get a straight through exhaust pipe installed which may cause it, but please explain if not.
    2: brake shuddering
    When i am driving about 100km/h and i slowly put the brakes on, my car shudders, as if maybe a brake is buckled or something and even when i go over 120km/h to overtake, my car will shake. It's a bit scarey for my friends hahaha.
    My brakes squeel too, like that usual high pitch noise when braking..and when i am braking at a very slow speed, u can feel and hear that it's not a smooth brake, it's rather jumpy (coz the squeeling noises stops and starts etc).
    3: sticky clutch or accelerator:
    when i change gears, (yes it is a manual ) my revs will actually go UP when im in the process of changing gears. and if i slow down and hold the clutch in, my revs will stay high and not go down. ALSO, when i start the car up to reservse or go forward, when releasing the clutch and putting down the accelerator, it's as if it doesn't register the accelerator properly and it almost stalls, sometimes i even have the accelerator very far down. Then after time it will finally pick it up and rev high, but as i keep reversing, it'll do the same thing over and over.
    That's about it. Sorry if it's hard to understand what im trying to say, im not a mechanic or anything obviously, just a P plater in QLD lol.
    cheers anyway, any help will be much appreciated =D
    1998 VT Acclaim S1
    Feb 2008
    1. Check or change your leads, spark plugs, coil packs. Also see if your car needs a carbon clean. Otherwise you can disconnect the battery to reset the computer, and see if that helps with the rough idling.
    2. Sounds like a combination of many things...what tyres are you running on and when have they been balanced and rotated? You could try machining your rotors and see if that helps with the shaking on braking. Standard commodore brake pads are generally noisy. I've changed mine to Bendix CT pads and they are a bit more quieter on braking.
    3. You could try tightening your clutch and accelerator cables a bit to get a more positive response. If its sticking, it could be just dirt and grit getting caught on the cable and joints. Try cleaning and oiling.
    fitz_vt's Avatar
    fitz_vt is offline Pass Me A Wrench.....
    VT Commodore SII Olympic Edition
    Nov 2008
    Adelaide - South Side
    Quote Originally Posted by JoeFish View Post
    1: Shaking alot
    2: brake shuddering
    1. your vehicle is shaking alot due to wear on your engine mounts... the vehicles engine mounts will make the vehicles engine move and touch the frame causing vibration.
    2. your brakes sqeal and shudder because you need to have your discs machined and pads replaced. a mechanic would be able to tell you this.
    3. your clutch plates are probably worn, and your cables probably need replacing shouldnt be too expensive but certainly take it to a mechanic to have it done as it is hard to do unless you have tools to do it and you probably dont.
    |VT Olympic Edition 3.8L Ecotec | VY S Pack Green Interior|
    Mods to come | VY Map Reading light/Sunnies Holder|
    "Give me a minute, I'm good. Give me an hour, I'm great. Give me six months, I'm unbeatable."
    98 VT Executive
    Aug 2008
    Sunshine Coast
    Thanks for all the help, it has really helped!!
    I will be taking my car into the mechanic soon, so i will tell him what's going on and what you have suggested, thanks heaps!!
  1. vn v6 commo
    By cruza in forum Electrical Wiring / Questions
    Last Post: 09-02-2008, 04:24 PM
  2. Which commo should i get?
    By PEAKN6 in forum General
    Last Post: 07-11-2006, 01:46 PM
  3. sik commo
    By jaikai in forum Jokes/Humour
    Last Post: 23-05-2006, 12:17 PM
  4. vr bt1 commo v6 FS .... maybe
    By nathsvrbt1 in forum Parts And Other Items For Sale
    Last Post: 06-02-2006, 02:29 PM
  5. Grr @ my commo
    By tm659 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 09-09-2004, 10:21 PM
Tags for this Thread
