Results 1 to 19 of 19
Thread: WTF Dude!
    1998 VT Executive 3.8ltr V6 Series I
    Nov 2008
    Exclamation WTF Dude!
    Okie doke...
    I was driving along and all of a sudden my car started rough idling for about 3 seconds and then stopped...I was like $%#!...I looked at the telltale lights and noticed the check engine light was illuminated. I then started it again...it ran normaly for about 10 seconds and then stoped again. I rang RACV and the bloke came out and checked the battery first up...he said it was dead which it was so I had it changed...started up and it went for about 5 minutes and stopped again...Boy did I have the #@^%'s now! Got the RACV out again and this time made the mechanic check it thourghly...He suspected a faulty DFI module.
    Do you guys/gals think that this is what is causing my issues? I think it could be out of the CAS, DFI or the coils.
    Cheers, Dwighty
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Best thing to do is check the fault codes and that might guide you in the right direction. When the check engine light comes on a fault code is logged.
    Here is a link to thread that explains how to read fault codes. You'll have to read a few of the posts before you get to it.
    Power Train Light
    MY RIDE
    Nov 2008
    Ummm Crap!....I just tested for codes....all that I could see was 12 so that must be a good thing.
    BUT!...when I was doing it a second time I accidently touched another connector which sparked...Now when I turn the key to accessories I get 3 series of beeps and what looks like the airbag light
    I am guessing a major problem now
    PS: I disconnected the battery for about 15 secs and tried again and same thing happened. I have noticed also the fuel pump wont activate, I have no central locking also. I have check all the fuses and they are fine.
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Did you check the fuses in the engine bay and under the steering column?
    To get rid of the airbag light you have to get it reset by Holden ot someone with a Tech 2.
    MY RIDE
    Nov 2008
    Quote Originally Posted by accentstencil View Post
    Yeah I checked all relevant fuses in bonnet and under steering column...all I get is the system check, can not hear the fuel pump, and then the airbag light illumintaes and I get 3 beeps 3 times (beeep beep bep, Beeep beep bep, Beeep beep bep) CD player works, No central locking and wont crank at all.
    I might have to cut my losses and take it to an auto elec
    Should have just $#%^in left the $%# and not tried myself
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    I think maybe your fuel pump was the reason for your earlier breakdowns or did the RACV guy rule that out?
    MY RIDE
    Nov 2008
    Ruled it out...when it started to shudder you can hear the pump still working so he said it can't be the fuel pump.
    And futher to the BCM...I think I have frozen it. Does anyone know if you can reset it or do I have to get a new one or reco one?
    fitz_vt's Avatar
    fitz_vt is offline Pass Me A Wrench.....
    VT Commodore SII Olympic Edition
    Nov 2008
    Adelaide - South Side
    Quote Originally Posted by Dman86 View Post
    ok disconnect you battery for 1 minute, this will thoroughly reset your BCM ECU and airbag module.
    apparently it thinks you have set of the airbag its a safety feature that when it thinks or the airbag has been deployed it will shut off the fuel pump and all electrics except for the lcd display but sometimes it will even shut this off to, i have seen this many times and i am not even a mechanic.
    just to be sure AFTER DOING THIS HAVE YOUR AIRBAG TESTED AT A HOLDEN DEALER AS IT DID NOT DEPLOY THERE IS A FAULT IN THE SYSTEM!!!
    |VT Olympic Edition 3.8L Ecotec | VY S Pack Green Interior|
    Mods to come | VY Map Reading light/Sunnies Holder|
    "Give me a minute, I'm good. Give me an hour, I'm great. Give me six months, I'm unbeatable."
    Nov 2008
    Quote Originally Posted by fitz_vt View Post
    Didn't do a thing brother ...still doing the same as above. Thank you anyway.
    fitz_vt's Avatar
    Nov 2008
    then there is a large fault in the electricals, try checking the fuseable links in the engine bay fuse box it is located on the drivers side behind the washer tanks if there is something major shorting out it will be blown if not try and ring holden for them to bring a techie with a techII out to diagnose the problem but may be expensive.
    but if not your air bag is F**cked.... replace the airbag and get a holden techie with w tech II or your auto elec to reset the airbag switch
    '08 60th Anniversary VE Sportwagon
    Nov 2004
    Dman86, any update on your issue? I'm having simliar issues and want to get it sorted ASAP.
    Nov 2008
    Quote Originally Posted by Sammo79 View Post
    Hey Sammo79
    Yeah my car is fixed now. Took it to Holden, they reset the codes and found my fuel pump was kaput! It was draining heaps of power which explains why my last battery only lasted 6 months
    What sort of symptoms is your car having?
    VR V6 Manual
    Aug 2008
    Central Coast, N.S.W
    Nov 2004
    First of all my remote won't lock/unlock the car, the car will turn over but cut out straight away and the red light on the dash keeps flashing. BCM is my guess. The car's been sitting in my garage for 2 weeks now......
  15. #15
    VR V6 Manual
    Aug 2008
    thats same except mine just clicks wen i turn key. i clutch started it but died after a second. but it all started wen i was driving it. all my gauges except revs stopped working lights dimmed then turned off and injectors stopped firing. had to get it towed home.
  16. #16
    Nov 2008
    Check your battery isn't dead...If that is fine then you should get it to Holden. It might just be a case of reseting the BCM.
    Which red light is flashing and does it have any beeping along with it?
  17. #17
    Nov 2004
    Ended up killing the battery after too many unsuccessful starts.... Had it on the charger all day yesterday and battery was giving me full power last night.
    The flashing red light is the one above the Mode and Up & Down buttons- the immobiliser light..... No beeps.
  18. #18
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    When that light flashes the immobiliser is on, so the car won't start. I had that problem when I had my VT. Ended up having to replace the BCM. It could also be the key reader if you are lucky. You might need to get it the car checked out to avoid spending money on what it might be.
    MY RIDE
  19. #19
    Nov 2004
    I've had the key reader replaced on Monday. BCM = Bugga!
  1. Wheres My Car Dude?
    By Bilbs in forum The Pub
    Last Post: 11-08-2008, 01:42 AM
  2. Cop Vs Pizza dude
    By blacknight in forum Jokes/Humour
    Last Post: 01-03-2008, 04:12 PM
  3. see why this dude spun out
    By Boonz in forum Jokes/Humour
    Last Post: 14-09-2006, 09:37 PM
  4. dude, where's my chip?
    By wpnvrss in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-04-2006, 10:07 AM
  5. Fat dude singing
    By deserthead in forum Jokes/Humour
    Last Post: 05-12-2005, 11:39 PM
