Page 1 of 2 12 LastLast
Results 1 to 25 of 31
Thread: vx ss traction control
    vx ss sedan
    Nov 2008
    blacktown
    Default vx ss traction control
    here's a tricky 1 for you all........is it possible 2 permanently disable the traction control on my vx ss?
    if so.....how?
    [SIGPIC][/SIGPIC]a 10 sec pass is only a sniff of gas away
    MY10 SSV UTE
    Dec 2006
    Melb
    Default ..
    yes you can buy a traction control reverse loom comes with everything you need and takes like 20 mins to do
    fitz_vt's Avatar
    fitz_vt is offline Pass Me A Wrench.....
    VT Commodore SII Olympic Edition
    Nov 2008
    Adelaide - South Side
    or u can take the traction control fuse out but it may not work properly it might screw ur electrics
    |VT Olympic Edition 3.8L Ecotec | VY S Pack Green Interior|
    Mods to come | VY Map Reading light/Sunnies Holder|
    "Give me a minute, I'm good. Give me an hour, I'm great. Give me six months, I'm unbeatable."
    vx ss sedan
    Nov 2008
    blacktown
    Quote Originally Posted by lumina01 View Post
    any idea who sells em?
    dijm8's Avatar
    dijm8 is offline What You Looking At
    VZ SS LS3
    Jun 2006
    BOGANV8's Avatar
    BOGANV8 is offline I gotta V8 whoot whoot
    VX 02 SS LS1
    Dec 2005
    Armidale
    Im also keen on this idea as everytime i start the car now i do the in D or R and push the button as a start up thing....
    I was thinking of trying to find out what 2 wires they use to turn it off and maybe jumping them together so that it thinks the switch is always turned off.... but not sure if this would work.......
    In my gregories it looks like its just one wire in RED&WHITE & BLACK&GREEN opu which goes to earth but i thinking it could be that siple to just earth the RED&WHITE wire.. dont really want to do damage
    vx ss sedan
    Nov 2008
    blacktown
    Quote Originally Posted by BOGANV8 View Post
    yeah its in the 2 hard basket......the cars going back to sams performance soon.......i'll get his opinion as he's the LS1 king
    3.8L GT35 4runner/VK calais
    Dec 2006
    Nowra
    Quote Originally Posted by dijm8 View Post
    yes u can....get ur tuner to do it for u...he done mine with i had the cam in
    as far as I know it can be switch off in the tune
    so I dont know whats has been done to yours
    cheers GM
    minux's Avatar
    minux is offline Infidel Bear
    300rwkw FG G6ET/2011 Sti Spec R Hatch
    Mini Putt 2 Champion!
    Feb 2005
    Quote Originally Posted by GMMAD View Post
    Yeh I didn't think it could be switched off either.
    Whats the legality of having a TC switch "disabled" so to speak?
    "Be who you are and say what you feel, because those who mind don't matter and those who matter don't mind."
    - Theodor Seuss Geisel
    Dec 2006
    Nowra
    Quote Originally Posted by minux View Post
    I know speed inc make a TC default off loom
    which just turns off the TC when the ignition is turned on
    and if you want it on you just push the TC button and it will turn on
    cheers GM
    adamc11 is offline Donating Member
    VY SS
    Feb 2008
    E. & W. Suburbs Melbourne
    Cop cars come with it off standard don't they? Surely it can be changed in the tune.
    Dec 2006
    Nowra
    Quote Originally Posted by adamc11 View Post
    there is a way of doing it but it isnt in the tune
    cheers GM
    vx ss sedan
    Nov 2008
    blacktown
    when i had my edit and mafless tune done sam was unable to disable from his laptop.......he suggested going to holden
    vx ss sedan
    Nov 2008
    blacktown
    from what sam (from sams performance) has told me if you do manage to disable the TC and are involved in an at fault accident you may have a case to answer........i think he said there was such a case going through the courts at the time.......so tread carefully people........might leave mine alone.......its ONLY a push of a button after all
  15. #15
    MY10 SSV UTE
    Dec 2006
    Melb
    Default ...
    im sure any hp or efi live tuners can play with it and set how much traction you want.
    but as said earlier just order a reverse loom from speedinc and fit it yourself.
  16. #16
    vx ss sedan
    Nov 2008
    blacktown
    do u know if they are legal?
  17. #17
    vx ss sedan
    Nov 2008
    blacktown
    my brother in law has a vy ss ex chaser has no TC fitted from factory , no button , nothing
  18. #18
    burnz's Avatar
    burnz is offline dah dut dut da dah
    2010 CRUZE Diesel
    Jun 2005
    springfield
    traction control is a part of the A.B.S. system and has to be programmed using bosch fire wire as far as i know.
    it has nothig to do with the tech II softwear.
    Research has shown that men usually sleep on the right side of the bed.
    Even in our sleep we happen to be right.
    Powered By Garrett
  19. #19
    BOGANV8's Avatar
    VX 02 SS LS1
    Dec 2005
    Armidale
    Quote Originally Posted by mr LS1350 View Post
    Ok so are you meaning play with and turn it off permanently..
    Cause if you turn it off (via button) and go for a drive and have at fault accident then its not going to work the same as disabling it it wont work either.. seems like a strange thing to have happen....
  20. #20
    burnz's Avatar
    2010 CRUZE Diesel
    Jun 2005
    springfield
    i don't think it actually illegal, but maybe insurance company's would use as an escape clause.
    Powered By Garrett
  21. #21
    vx ss sedan
    Nov 2008
    blacktown
    i was talking about totally removing/disabling the TC ..........sometimes i forget to press the TC button (upon start up) and its annoying when the TC forces up the accelerator ..........but if its too hard or causes legal issues in an accident too remove it i'll leave it alone
  22. #22
    TrEnNaVY's Avatar
    TrEnNaVY is offline Donating Member
    VY S V6
    Nov 2008
    if u turn it off(at button) and light em up does it kick back on or stay off??
  23. #23
    MY10 SSV UTE
    Dec 2006
    Melb
  24. #24
    BOGANV8's Avatar
    VX 02 SS LS1
    Dec 2005
    Armidale
    Oh ok now i understand
  25. #25
    BOGANV8's Avatar
    VX 02 SS LS1
    Dec 2005
    Armidale
    Quote Originally Posted by TrEnNaVY View Post
    Stays off and frys the tyres....
  1. Traction Control
    By batty_123 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-07-2009, 07:52 PM
  2. Traction Control / Cruise control crapped out!!
    By DarkCrystal in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-02-2008, 06:37 PM
  3. vy sv6 traction control
    By phat_com in forum General
    Last Post: 11-01-2007, 03:56 PM
  4. Traction Control
    By bertvj in forum VY Holden Commodore (2002 - 2004)
    Last Post: 28-06-2006, 02:01 PM
  5. VY Traction control?
    By atreidae@optusnet.com.au in forum Electrical Wiring / Questions
    Last Post: 30-01-2006, 11:50 PM
