Results 1 to 21 of 21
Thread: how do i prime an oil pump
    VTHSV
    Jan 2008
    Default how do i prime an oil pump
    i own a 5 litre manual vt clubsport
    I replacing the oil pump, how do you prime the pump,
    ive heard that you put vasoline in it, is this correct, if so do you pack the whole pump full of vasoline, or just lube the gears and gear shaft then fill it with oil and fit the pump (filter included) to the car
    Mar 2008
    Yeah mate pack the pump gears full of Vaso and fill the filter with oil.Remove the spark plugs so the engine spins fast and watch the O/Pressure gauge
    VTHSV
    Jan 2008
    VTS5's Avatar
    VTS5 is offline TechJunkie
    '97 VT Spack 5 Speed
    Jul 2005
    Sth.East\Melb
    Quote Originally Posted by hrtmad View Post
    how long do i let the engine turn over intill i get normal oil pressure
    'Till the oil pressure light goes out..
    fitz_vt's Avatar
    fitz_vt is offline Pass Me A Wrench.....
    VT Commodore SII Olympic Edition
    Nov 2008
    Adelaide - South Side
    pretty much once you have vaso'd it once u whack it in put ur oil in, then run your vehicle for 5 minutes at least bring it to the normal operating temperature (75-100 degrees) once that has happened your oil pressure light should turn off if not even before then. * should turn off*
    if your light does not turn off ..... TURN OFF YOUR ENGINE, let it cool down and as posted below start again.
    Last edited by fitz_vt; 16-11-2008 at 04:57 PM. Reason: addition and subtraction of stuff in my message
    |VT Olympic Edition 3.8L Ecotec | VY S Pack Green Interior|
    Mods to come | VY Map Reading light/Sunnies Holder|
    "Give me a minute, I'm good. Give me an hour, I'm great. Give me six months, I'm unbeatable."
    VT
    Apr 2005
    QLD
    Quote Originally Posted by fitz_vt View Post
    then run your vehicle for 5 minutes at least bring it to the normal operating temperature (75-100 degrees) once that has happened your oil pressure light should turn off. * should turn off*
    if not run your engine until the light goes off if the light doesnt turn off you have done something wrong. turn off your engine let it cool down and inspect the pump.
    I personally wouldn't run my engine with the oil pressure light on for 5 minutes lol that is asking for trouble.
    get a proper oil pressure gauge and use that. the principle is, the gear pump that pushes the oil around your engine isn't real good at self-priming (not a good air seal) so packing it full of vas or grease maintains this seal, so when the pump is rotated it can create negative pressure on the intake and the oil makes its way up the pickup so the pump can operate as planned.
    VY SII HBD Calais L67
    Dec 2006
    It should quieten down after 1 minute or so max. If it doesn't, time to start again
    VYII Calais L67
    fitz_vt's Avatar
    Nov 2008
    Quote Originally Posted by VT-565 View Post
    yeah essentially what needs to happen is for the oil pump to engage, and start pumping oil around the engine.... to do this properly the engine needs to be at normal opearting temperatures........
    VTHSV
    Jan 2008
    So what is better to pack the pump with grease or vaso, i was actually gonna use both hail storm and fitz_vt's idea, turn the engine over with plugs out untill the oil pressure light goes out, then run car for 5 mins till normal oil pressure is achieved.
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    yeah just vaso,
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    VT
    Apr 2005
    QLD
    lol....if the oil pump isn't turning, he's got big dramas. It's either turning or its not, there is no engaging or disengaging....
    If you pull the plugs and turn the engine over, you should see good oil pressure in less than a minute as mentioned....It just sucks that you have to turn the engine over so long to get it. That's why the holden iron 8's suck balls, you can't prime them with a drill like chev, ford, chryslers....
    VTHSV
    Jan 2008
    once its primed and engine is running and everything is sweet, do i need to change the oil again to get rid of the vaso, or will it be fine to run on untill the next oil change
    VT
    Apr 2005
    QLD
    I'd do a change to be on the safe side, at least to get rid of any foreign materials that might have found their way in.
    pablo is offline Donating member
    Was a 1997 vt v6 wagon
    May 2006
    I personally wouldn't be putting vaseline in to prime the pump. I have used just ordinary chassis or wheel bearing grease in the past to do this. Not much is needed, just enough to 'wet' the gears. When it pumps through it will just mix with the oil after it finds its way through the filter.
    Pablo
  15. #15
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    as stated it only needs a light smear to fill the tolerances in the pump to seal it up, the vaso will melt very quickly and wont affect the oil once it all mixes up,
  16. #16
    fitz_vt's Avatar
    Nov 2008
    well essentially it works in other words engage,activate, begin, energize, get started, ignite, initiate, introduce, log on, put in gear, put on, set in motion, start up, switch on..........
  17. #17
    VTHSV
    Jan 2008
    So just pack the pump gears full of vaso or both the gears and the round hole about 15 mm in diameter beside the pump gears, which i assume is hole that either sends or returns the oil from the engine
    Attached Thumbnails Attached Thumbnails how do i prime an oil pump-photo0008.jpg
  18. #18
    howepower's Avatar
    howepower is offline Donating Member
    vc commodore sl
    Nov 2008
    KIELOR DOWNS
  19. #19
    VTHSV
    Jan 2008
    Thanks Guys for all your help, have just installed the oil pump with no worrys
    HRTMAD
  20. #20
    fitz_vt's Avatar
    Nov 2008
    HRTMAD
    good on ya mate
  21. #21
    VT
    Apr 2005
    QLD
    Okey Dokey, Captain Thesaurus.
    In your original post it sounded like you were saying the engine needed to be at operating temp to engage and pump oil around the engine. Water under the bridge.
    Good to see you got things happening HRTMAD.
  1. .: My Son Optimus Prime :.(Bleach)
    By kowan in forum Jokes/Humour
    Last Post: 27-02-2008, 07:36 PM
  2. painting my engine. should i prime?
    By sebstenator in forum General
    Last Post: 18-02-2008, 11:48 PM
  3. fuel pump doesnt prime
    By Burnout_bro in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-02-2007, 01:52 PM
  4. how do i prime a vl oil pump
    By 3428scott in forum VL Holden Commodore (1986 - 1988)
    Last Post: 29-10-2005, 09:41 PM
