Results 1 to 12 of 12
Thread: Rear End noise
    VT Executive
    Oct 2008
    Default Rear End noise
    Hey people, just wondering if you can help me out. I have a 98 VT, i have it lowered with Koni shocks and Lovell springs, as well as a camber kit. My question is, can lowering it throw the alignment of the tail shaft out? I have this noise, and this may sound weird but its the only way I can describe it, it sounds like a wheel when it is out of shape and not round! Haha. It is there at lowere speeds and gets more noticeable at higher sppeds. Doesnt affect take-off, cornering etc
    Anyway cant be the tyres or wheels as they are brand new, it isnt the brakes or pads as they are new as well. I am thinking its diff, drivetrain or something around there. Just wanting to get some ideas before I take it somewhere to get it looked over.
    Cherrs
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    lowering wont affect the tailshaft on an irs car as its in a fixed position,
    described it like a wheel bearing, does the pitch change when you swerve the car? if the noise gets quieter when you swerve the bearing thats stuffed is on the opposite side to the one you've swerved, also check movement in the bearing,
    if in doubt go to a mechanic
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    fitz_vt's Avatar
    fitz_vt is offline Pass Me A Wrench.....
    VT Commodore SII Olympic Edition
    Nov 2008
    Adelaide - South Side
    this noise indicates worn or fault suspesion components check and change if faulty.
    the things you need to have checked are that
    1. control arm bushings (may be worn)
    2. suspesion test (press down on suspension and see how quickly it bounces back if it bounces back quickly then your shocks are ok if they are really slow they need replacing.
    3. check rear end alignment
    |VT Olympic Edition 3.8L Ecotec | VY S Pack Green Interior|
    Mods to come | VY Map Reading light/Sunnies Holder|
    "Give me a minute, I'm good. Give me an hour, I'm great. Give me six months, I'm unbeatable."
    VT Executive
    Oct 2008
    Cheers for your help guys. fitz_vt, cant be the suspension as all the compenents in the suspension are new, only had them about 2 months. Its just annoying cos I notice the noise now every time I drive it. O dont think its doing any dtremental damage, I hope.
    Im hoping that its just something to do with the camber in the car.
    fitz_vt's Avatar
    Nov 2008
    Quote Originally Posted by cjcrow View Post
    yeah definately if not take it back to the place you brought your suspension from and get them to check it over (its still under warranty right)
    Claudy's Avatar
    Claudy is offline French Com
    Manual Gen3 VT SS + V6 VT manual turbo
    May 2006
    Perth, Two Rocks
    hey dude,
    had same problem with my car, like ticking noise, was the CV boots needed repacking. hope this helps. let me know if you need more info
    Gen3 6spd Manual VT SS
    VT V6 Manual turbo
    madcapmagician is offline Phatburger fanatic
    02 VXII Berlina 3.8
    Nov 2008
    Toowoomba
    Hi
    I've had a rear-end knocking noise in my VXII berlina for years. Holden replaced the diff 4 times under warranty thinking it was that but it did not fix the problem. New shocks were fitted - no change. About a month ago the rear right shock started making horrible noises - turned out the bottom bolt had worked loose. Funny thing was, tightening it back up with the rattle gun, we noticed that the bolt didn't run smoothly in the thread - like it was binding inside. At maximum tightening, we don't believe the bolt has tightened against the sleeve so much as binding up the thread. The washer only just is held firm, giving the impression that the bolt is tight, but after driving for a few k's the noise comes back and it is the tiniest, tiniest bit of play at the bottom the shock. I'm really worried now about getting the bolt out - the bolt itself is no problem - $3.50 for a new one, but if the lower control arm is stuffed, that's gonna hurt.
    If it turns out that I can't get the bolt out without destroying the thread in the control arm, I'm going to try drilling it out to 15mm and cutting a new thread and getting a bolt to suit.
    Has anyone ever found out what the bottom bolt (part number 92036304) actually is? It is the weirdest size - very close to 9/16, but it isn't SAE, isn't metric, isn't whitworth - it is some weird size and it has an even weirder thread. Would love to know what it is....
    Pete
    VT Berlina Wagon S1
    Oct 2008
    Seems to be common enough to call this a design/manufacture fault... mine went bung in the same way too. Was fixed by drilling the hole all the way through and inserting a longer bolt with a nut on the other side. Not elligant, but works fine. Option would be to helicoil (helical thread fixer upper) it.
    Quote Originally Posted by madcapmagician View Post
    Hi
    Pete
    VT Berlina Wagon S1
    Oct 2008
    What will effect the tailshaft geometry is your engine mounts. My 98 VT has saggy ones, being changed soon, and the sump is mer millimetres from the crossmember. This could equate to a fair change of possition/angle at the back of the transmission.
    Another option is that your tailshaft isn't balance well. Check it for tar spots, clumps of body deadner, etc, anything that wasn't welded to it before it was ready for painting at the factory.
    Cherrs
    VT Executive
    Oct 2008
    Hey people, just an update, the noise wasn't actually coming from the rear, it was just resonating through the car and sounding like that (i feel like a dick!!). Anyway the front drivers side wheel bearing is gone, i'm getting it done on friday morning. I will update you all on how it comes out. Thanks everyone for their help, much appreciated!!
    VT
    Apr 2005
    QLD
    Quote Originally Posted by fitz_vt View Post
    Where did you get that from?
    If your shocks are f.ucked, it will keep bouncing. If they are slow, at least you know the valving is working lol
    VT Executive
    Oct 2008
    Hey ppl, just an update, got my front bearings changed and an unbelievable ride now!! No front end noise and no vibration when I get up around 100 clicks. Very pleased. Now just gotta work on a few things and then I'll post some pics. Cheers everyone for all your help
  1. knocking noise in rear of sv6?
    By crewzincool in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 13-12-2007, 01:44 AM
  2. rear noise in wagon
    By Johnno.o in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-12-2006, 08:02 AM
  3. Rear End Noise...
    By jwoods997 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-09-2005, 10:26 PM
  4. Rear driving noise
    By LYRIC in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-08-2005, 11:37 AM
  5. thudding noise from rear of car
    By jacob1986 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 08-07-2005, 01:29 AM
