Results 1 to 3 of 3
Thread: Calais spec gauges in an ss
    VT SS S1
    Nov 2008
    Default Calais spec gauges in an ss
    Can someone please help?
    i have a S1 VT SS 5.0 w/ 5 Speed.
    I have just bought a gauge pod out of a WH Statesman.
    It works perfectly accept for the tacho, at idle it sits at 2500 rpm.
    i have read about the fuel gauge not working, but it is great.
    All other functions work perfect, the digital tacho (through holding down 'Mode' and 'Up') is accurate just not the main tacho.
    this isn't a big issue as i have had the car for a while and know rev range very well, but it's enough to drive me crazy at times.
    Also,
    Can the small 'x' in the bottom of the left window get cleared off?
    Obviously that denotes a problem, how could i find out what the problem is (if it is seperate to the tacho)
    VT Berlina S1
    Sep 2007
    It sounds like you just need to visit a Tech 2 and have it update your cluster with the correct information about your car
    the x usually indicates a fault / error, but if your dash isnt configured correctly, id be hardly surprised if it threw an error....
    3.8L GT35 4runner/VK calais
    Dec 2006
    Nowra
    the X is there because the stato has climate control and the lower model dosent
    I wouldnt worry about it
    try a tech 2 to fix the tacho
    cheers GM
  1. L67 Spec ???
    By sixshooter in forum V6 Development And Modification
    Last Post: 19-11-2011, 10:21 AM
  2. VN Vacationer spec
    By jack.mc in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-03-2009, 11:58 AM
  3. Difference between VR SS and HSV spec SS
    By shanhsv in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-08-2008, 11:31 PM
  4. VN Calais, Sticky Gauges??
    By Mitch_calaisVN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-11-2007, 06:03 PM
