Results 1 to 7 of 7
Thread: Are the VT & VX SS LSD interchangeable
    VX II SS Ex Chaser V8
    Jul 2005
    Default Are the VT & VX SS LSD interchangeable
    Hi guys
    Are the LSD from the SS VT & VX the same diffs, can I swap them over??
    Jesterarts's Avatar
    Jesterarts is offline Your freedom ends where mine begins
    2005 HSV Z R8 Manual
    Nov 2005
    Mornington, VIC
    As we talking the LSD centre of the complete diff?
    If we're talking complete diff you will need to have the axles and yoke modified...
    Its not a straighgt "plug n play"
    Good luck.
    GMM CAMMED and STALLED VT SS 5.7
    Sep 2007
    Melton,Victoria
    Jesterarts's Avatar
    Nov 2005
    Mornington, VIC
    They are not straight interchangable...
    VT Diff... series I and II have a metal yoke joining to the tail shaft (image 1)
    The VX onwards have a 3 prong yoke joining to the tailshaft via rubber thingy (image 2)
    You can get it swapped over but it'll cost you...
    Found this out when i was trying to get a VTII 3.73 LSD on my VX.
    Attached Thumbnails Attached Thumbnails Are the VT & VX SS LSD interchangeable-vt.jpg   Are the VT & VX SS LSD interchangeable-vx.jpg
    Sep 2007
    Melton,Victoria
    Jul 2005
    OK, I was hoping to get a complete diff and just bolt it in. I do not have the time to pull down gears etc. Mine just has noisey bearings, or I believe that is the problem. At 50-60 clicks it is the worst, when you back off it nearly goes away. So if the VX SS LSD is not compatible with other models then this is the diff I must have !!
    Jesterarts's Avatar
    Nov 2005
    Mornington, VIC
    VX and VY are the exact same diff.... 95% sure the VZ is the same aswell... just the gears in the v6 versions are weird (low ratio).
    They swapped the yoke setup after vt. THe idea was to with the rubber thing, any gears from the tailshaft are absorbed abit...
    I put a VY GTO 3.73 diff into my vx... bolted straight on.... VT is not a straight bolt on, need to change the yoke. Get a quote for getting it swapped cause it might only be still cheaper to get a VT diff and swap it rather than looking for a VX onwards diff.
    Good luck mate
  1. VZ-VT headunit interchangeable?
    By ascension24 in forum Car Audio
    Last Post: 04-08-2008, 11:08 PM
  2. VT and VX panels interchangeable?
    By TGibson in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-09-2007, 10:24 AM
  3. interchangeable parts
    By mrbeef in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-01-2007, 10:19 PM
  4. VN VP VR Mainfolds... Interchangeable?...
    By g00gz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-07-2006, 07:33 PM
  5. Are series 1 & 2 engines interchangeable?
    By Tadeusz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-12-2004, 10:47 PM
