Results 1 to 16 of 16
Thread: VX SS Digital Vs Analog speedo reading
    VX II SS Ex Chaser V8
    Jul 2005
    Default VX SS Digital Vs Analog speedo reading
    On my VX SS Ex-Chaser I have the normal speedo and also a digital speedo where the oddometer is. According to another web site the following text appears.
    Any VT/VX/VY Commodore can have the "Police Mode" digital speed indication feature enabled under the Speedo dial with Tech 2 at a dealership. Takes about 3 minutes. In doing this, the vehicle looses the Speed Alert feature.
    Do any of you other VX SS owners have the digital speedo activated as standard or is it actually a "Police Mode".
    Inside my drivers door there is a yellow sticker that certifies the speedo accuracy as being tested. Would that have been for the dash speedo, the digital speedo or the Police radar setup ???
    There is a 4km/h difference between my analog and the digital, which do I believe ?
    Jul 2005
    Ozzie's Avatar
    Ozzie is offline JCCC Warrnambool
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    the police have it specially activated.
    all vt's and vx's have the option. to activate mine without a tech2 i need to hold down mode & set^ when i start th car.
    only problem with it not being permenantly activated is that i have to do this step everytime if i want to use the feature.
    by having it activated by a tech2 from holden, they are able to permanetly activate it.
    Jul 2005
    Thanks Ozzie, which do you think is the most accurate speedo, the big dail or the digital??
    fitz_vt's Avatar
    fitz_vt is offline Pass Me A Wrench.....
    VT Commodore SII Olympic Edition
    Nov 2008
    Adelaide - South Side
    well the LCD screen and the Big dial are fed by the same ECU........
    so enevitbly they are the same reading your speedo needle must be out but if it has been checked for accuracy its been a cop car and maybe you should have it adjusted or checked have you put aftermarket rims on it??
    |VT Olympic Edition 3.8L Ecotec | VY S Pack Green Interior|
    Mods to come | VY Map Reading light/Sunnies Holder|
    "Give me a minute, I'm good. Give me an hour, I'm great. Give me six months, I'm unbeatable."
    Ozzie's Avatar
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    Quote Originally Posted by fitz_vt View Post
    yep exactly.
    the digital speedo is the main reading. it gives out the reading to the analog speedo
    Jul 2005
    OK, thanks guys,
    no original cop rims.
    Will get it checked, don't want to get pinged by a radar.
    Full Spectrum's Avatar
    Full Spectrum is offline Customize your life.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    I just wish Holden would have all options in the trip, Instead of searching through buttons before you start.
    Quote Originally Posted by Yoda
    Do, or do not. There is no 'try'.
    <img src=http://forums.justcommodores.com.au/signaturepics/sigpic440_66.gif border=0 alt= />
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    You can go into Holden and get them to unlock this feature on your car. It over-rides your speed alert, as said, but who needs that if you've got a digital readout.
    Had this done the day after i got my SS.
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    Oct 2003
    Not correct.
    The PCM has direct input from the sensor and what it calculates is what is displayed on the digital readout directly to that readout. The analog on the dash is feed from the pcm via the BCM to the dash (which uses it own calculations based on pulses per minute ppm). The tech 2 can adjust the PPM to correct the analog gauge, and back when it was a cop car that probably what they adjusted. So the analog gauge would be more accurate, unless you have changed rims, diff ratio etc.
    The problem being is using the Tech 2 to adjust PPM, this only adjust the dash analog gauge and not the PCM. More so a problem with gear ratio changes. the PCM still sees the uncorrected speed, so rev limiter and auto gear box changes are out as the pcm controls them based on what it sees. It will change gears at the wrong time, possibly over the limiter (depends what ratio you go to). Which means you could hit fuel cut on the limiter before it changes. but the dash will be right with PPM adjustment only, just the engine will not be right.
    The best way to adjust the speed is via the PCM. Holden can't do that at dealers, if they can they are taking them to a tune shop. Tuning programs will adjust the PCM for tyre size, rim size and diff ratios in the pcm so it sees the right speed at the pcm. but for a cop car to be deadly accurate on the analog gauge they adjust it by tech 2, on a regularly checked dyno, as Oem they are about 5 kph out on purpose.
    At one stage when i changed ratios the PCM indicated speed was 10% out to the dash when adjusted via tech 2 only many years ago. Currently my digital is 1 k out at 100k, the dash is 6 k’s under in comparison to the GPS unit.
    analog reads OVER as per most oem dash analog readings, they do that on purpose as manufacturers are not allowed to read under, or everyone would be speeding. So At 100 KPH on a OEM dash you will really be doing about 95 kph, most ppl drive 5 kph over, so they are actually doing the right speed then 100 kph. But be warned 5 kph at 100 kph is not 5 kph difference at 60 kph, its a % factor.
    Anyway to answer the posters question, run it on a dyno or use a GPS unit. With a gps you need to sit on the hwy at a consistent speed for accuracy. Then you will know which one is closer…
    fitz_vt's Avatar
    Nov 2008
    Quote Originally Posted by 235rwkw View Post
    Not correct.
    basically what you have said i have somewhat made easier for others to understand, they are fed by the same damn sensor ok yes one goes through a BCM to interperate the data but essentially the same thing.....
    Oct 2003
    sort of. same original data, but handled in by 2 separate calculations
    one can be made to read 100 kph more than the other via adjustment of the calculations.
    his question was which is the correct one. depends which one was played with. i explained why the readouts can vary, how to check which is right and how to adjust either.
    Cop cars of this era usually had the PPK values adjusted to correct the speedo accuracy
    fitz_vt's Avatar
    Nov 2008
    yeah, its a sad thing with ex cop VT's and Vx's it happens but the speedos are easily fixed, you probably dont even need to return to holden for it.
    Jul 2005
    Thanks guys for your great input as usual. Will get it checked for peace of mind. Will let you know what happens. These Tech 2 gadgets, are they only handled by performance shops ??
    When everything's coming your way, you're in the wrong lane.
  15. #15
    wrx884's Avatar
    wrx884 is offline WA's ASR Rep
    VT Commodore Exec/5L VP Calais
    Mar 2006
    pretty sure coz u have a VX u can check ur needles urself using the trip button 2 see if they line up accuratly, u'll need 2 choose the hidden menu and scroll through and find the cluster check mode.
    fuel and temp needles should line up half way mark, the tacho at 3000RPM and the speedo should b at 100KM mark.
    hope that narrows it down further.
    Check out my ride in progress.... 98 VT V6, V8 Supercar kitted
    Daily toy.... 92 VP Calais 5L
  16. #16
    Oct 2003
    Quote Originally Posted by ozengines View Post
    nah tech 2 are at all holden dealers that can do all settings (except pcm editing), on holdens including ppk settings.
    some performance shops have a tech 2, mostly they have the correct tuning programs that edit the pcm, the correct way to make adjustments. Holden dealers can't do that, they can load programs, but not edit them. edit programs can change the rims size, diff ratio, tyre size pretty much anything in the pcm. but tune programs can't do ppk on the dash. dunno where you are, Sams performance sydney has both, and a dyno some cops come to get the speed set.
    A gps unit will tell you which is right. 4 k's isn't much to be out. So just find out which is right and compensate. too much trouble and money just to fix that really. wait till you get a tune and get that fixed at the same time. most of the time i just look at the speed on the gps, especially to set the cruise control right on the mark.
  1. Digital vs Analog Amps
    By azzfox in forum Car Audio
    Last Post: 02-11-2007, 10:57 AM
  2. 20s and speedo reading?
    By VL-187 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-01-2007, 05:26 PM
  3. speedo reading wrong
    By burns#44 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-11-2006, 09:10 PM
  4. Digital K reading just on VX or VT's aswell?
    By ascension24 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-06-2006, 06:55 PM
  5. Speedo Not Reading Correctly
    By driscolld in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-03-2006, 03:57 PM
