Hi all....whats the easiest way to get the motor out of my vt?? i,v spun a bearing and am pilling it out 2moz, one way or the other.
With my VN i found it easier to undo the K-frame and lift the body off it.
dont want to do that again if i have to....
any thoughts appreciated...
cheers davo...
L67 s/c v6
i would of thought the easiest option would be to take all the sh*t off then tilting the engine, front facing around 45 degrees and pulling it out in the same angle and direction
My VT Berlina [LIONLW] - Lowered, 18's, Leather
http://forums.justcommodores.com.au/...tml#post863216
If u got the equipment, take the bonnet out then lift the engine.I find it lot easier and less time consuming that way.
try the search button,
SIR LS1
the two ton go kart
yeah remove bonnet, un attach transmission from engine, get a-frame, attach a frame to engine, and simply jack up and remove.
|VT Olympic Edition 3.8L Ecotec | VY S Pack Green Interior|
Mods to come | VY Map Reading light/Sunnies Holder|
"Give me a minute, I'm good. Give me an hour, I'm great. Give me six months, I'm unbeatable."
