Results 1 to 3 of 3
Thread: VX Fuel Filter Change
    VX Acclaim Wagon
    Nov 2008
    Question VX Fuel Filter Change
    Hey sorry if this has already been posted but just wondering how you get the clips off either end of the fuel filter ...
    thanks
    VX Executive S2
    May 2006
    Frankston South Vic
    either remove the fuel pump relay until car stalls to drain fuel from line or Hold your breath close your eyes and enjoy the petrol all over you. Push the "hose" towards the filter then press the clips then pull hose away from filter.
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    You should buy the proper removal tool from Repco, Autobarn etc. for around $8. I found I had to trim around 5mm off the end to get it to fit properly. Depressurise the system as mentioned in the post above. I also wrap a rag around the end that I am disconnecting to catch any fuel spray. Petrol in the eyes is not very nice - it burns - have some water nearby to wash your eyes out just in case.
  1. How do I change a VT fuel filter?
    By k999 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-05-2012, 07:09 PM
  2. fuel filter change
    By ports in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 20-10-2008, 03:44 PM
  3. How to change a fuel filter?
    Last Post: 28-06-2006, 10:01 PM
  4. V6 VT wagon fuel filter change
    By batemada in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-05-2006, 12:10 PM
  5. Fuel Filter Change
    By Joatmon in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-04-2005, 03:56 PM
