Results 1 to 12 of 12
Thread: HELP - WH statesman dual zone climate control, interior fan no work
    '02 VX Berlina
    Apr 2007
    Adelaide, SA
    Default HELP - WH statesman dual zone climate control, interior fan no work
    my mate has a wh statesman which has just had front end damage repaired. its got a dual zone climate control unit.
    now, when he turns just the fan on, the fan doesnt come on at all. turn on the auto or air con, nothing comes on. all buttons work and change icons in the display, but theres physically no air blowing out cos the fans arent working.
    all fuses seem ok, but i coudnt really find a fuse that said 'dash fan'. i could hear the fan HIGH speed relay clicking under the dash tho. so thats working.
    im thinking maybe theres no gas in the air con thus why it isnt turning on??? i know with the units in vt executives for example, you can turn the fan on, but if you push the air con button on, the green light comes on but the air con doesnt turn on, and that means out of gas.
    any thoughts? thanks
    accentstencil's Avatar
    accentstencil is online now Donating Member
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    The fan fuse (fusible link) will be called Blower. The fan should work regardless of whether the air con gas is low or not. Also check the ventilation fan relay. Other reason could be a faulty fan speed resister or a faulty fan motor.
    MY RIDE
    VT Berlina Wagon S1
    Oct 2008
    If these are the same climate control units as the VT, try turning the fan onto its highest setting... if it works, then your fan speed controller has a fried transistor. This unit is behind the glovebox, to the right. There's a 3 pin and 4 pin variant between early and late, they're not interchangeable. One from a wrecker is about $35, or about $70 new from GMH.
    '02 VX Berlina
    Apr 2007
    Adelaide, SA
    i thought blower was supercharger.
    wheres the vent fan relay, under dash or in engine bay?
    wheres the fan speed resistor and fan motor?
    i turned fan to highest speed and still not working, although i can hear the high fan speed relay ticking under the dash. so does this mean resistor is ok?
    thanks for your help guys, hopefully my mate and i can figure out how to fix it.
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Both the fan and resister are behind the glove box. Not sure where the vent fan relay is but I did not see one in my engine bay.
    MY RIDE
    '02 VX Berlina
    Apr 2007
    Adelaide, SA
    we had a go at it today. my mate bought a second hand fan which we tried just by unplugging from the original one and into the spare. it still didnt work. i took a pic, is the resistor the white thing with a plug going into it? we'll try one out of my car tomorrow if that works, so we can try to further determine whats at fault. otherwise, where exactly are the fuses i should be checking? as we also replaced some dash globes and fuses today. what a headache...
    '02 VX Berlina
    Apr 2007
    Adelaide, SA
    i just went out now to my car and unplugged the white (resistor)???? and it is the same problem as my mates wh. so if the fuses are ok, then this is the fault. but which fuses do i check, before my mate takes the fan motor back in exchange for the resistor?
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    VT Berlina Wagon S1
    Oct 2008
    Behind the metal rail, at the top right of your picture, next to the barcode sticker, is the fan speed control module (resister, if you must call it this).
    VT Berlina Wagon S1
    Oct 2008
    fitz_vt's Avatar
    fitz_vt is offline Pass Me A Wrench.....
    VT Commodore SII Olympic Edition
    Nov 2008
    Adelaide - South Side
    the blower relay sounds like it i have my vt olympic (executive with options) loose high speed and only 1,2&3 works... its a relay under the steering wheel in the internal fuse box.
    |VT Olympic Edition 3.8L Ecotec | VY S Pack Green Interior|
    Mods to come | VY Map Reading light/Sunnies Holder|
    "Give me a minute, I'm good. Give me an hour, I'm great. Give me six months, I'm unbeatable."
    '02 VX Berlina
    Apr 2007
    Adelaide, SA
    thanks very much for all your input. this is the only help we got and we should have it all fixed up soon.
  1. Dual climate control unit
    By uhw893 in forum Electrical Wiring / Questions
    Last Post: 21-11-2008, 01:33 PM
  2. VZ Dual Zone Climate control symbols
    By hingo1983 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 28-10-2008, 08:05 AM
  3. statesman climate control to vn
    By 5speedcalais in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-01-2007, 10:56 PM
  4. VS Statesman Climate Control Problem
    By Wingnut0021 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-03-2006, 12:03 PM
  5. vq statesman dual fuel v8 or petrol v6?
    By Mazzone_Child in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-12-2005, 02:30 PM
