Results 1 to 7 of 7
Thread: radiator tank warning light and airbaglight on
    VT HSV
    Jan 2006
    Default radiator tank warning light and airbaglight on
    i threw a drive belt and got towed on back of truck to home and replaced with new drive belt and now i have constantly air bag warning light on and also the radiator tank warning light on .
    yes i do have enough water . have disconnected battery and restarted with no change . this car is becoming a nightmare last 3mths . any suggestions . is it job for tech 2 diagonsis .
    fitz_vt's Avatar
    fitz_vt is offline Pass Me A Wrench.....
    VT Commodore SII Olympic Edition
    Nov 2008
    Adelaide - South Side
    i would try changing the coolant first and see if the coolant light goes away if not its your coolant sensor thats throwing a spanner in the works i would have that changed or change it yourself, for the air bag light i would take it into a dealership for them to reset the airbag sensors and you possibly may need a new airbag, because they will need to test your current airbag.
    |VT Olympic Edition 3.8L Ecotec | VY S Pack Green Interior|
    Mods to come | VY Map Reading light/Sunnies Holder|
    "Give me a minute, I'm good. Give me an hour, I'm great. Give me six months, I'm unbeatable."
    Oct 2003
    check for damaged wiring from when the belt came off. coolant tank has a wiring underneath for low level. it could track forward before it goes back
    if the airbag wiring was also damaged that warning will need a reset by a tech 2
    afterwards
    VT HSV
    Jan 2006
    where would the coolant sensor be located also airbag wiring what should i look for . thanks for your help.
    Oct 2003
    Not sure just an idea if started after the belt.
    the coolant sensor wiring is under the coolant tank, follow that back and see if it comes forward and far enough to have been damaged by the belt.
    hsv it still runs a maf? i think not sure the wiring comes back up near to that wiring.
    air bag sensor wiring goes to the front also but can't recall where. just check any wires that could have been hit. or plugs that have come out.
    VT HSV
    Jan 2006
    yeah had afiddle with different wiring . dont know what i did but coolant radiator warning light has gone out now. but air bag light is still on and staying on. any ideas where a sensor for that is .?>?????
    accentstencil's Avatar
    accentstencil is online now Donating Member
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by gazzabrizz View Post
    Once the airbag light has come on there is no getting rid of it without a Tech2. See Holden.
    MY RIDE
  1. Alternator Warning Light & ABS OFF Light
    By Harvs82 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-01-2007, 10:10 PM
  2. 'Rear light bulb failure' warning light
    By Misaprop in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-04-2006, 03:07 PM
  3. radiator tank removal
    By Mark in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-07-2005, 04:11 PM
  4. Radiator Surge Tank
    By ChRiDDa in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-03-2004, 05:56 PM
  5. Radiator Tank
    By YBLGIT in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-02-2004, 05:51 PM
