Results 1 to 10 of 10
Thread: Issue: Won't start when warm.
    VT Executive Wagon
    Mar 2008
    Default Issue: Won't start when warm.
    Hey guys,
    I feel like a complete noob, but my vt won't re-start after its been warmed up. It turns over no worries, it just wont fire. Left for a couple of hours and it will start again. I dont know whether i should be replacing the coilpacks or what to be looking at.
    All help is much appreciated.
    vx ss sedan
    Nov 2008
    blacktown
    might be the crank angle sensor....its common on vt's.............when you do start it from cold does it cut out when hot?
    [SIGPIC][/SIGPIC]a 10 sec pass is only a sniff of gas away
    VS L67 Statesman
    Oct 2006
    Melbourne, VIC
    jazza15 is offline Jarryd
    1999 VT II S
    Jun 2008
    Eltham North, VIC
    pressure regulator? Once the engine is hot and the regulator isn't working properly, fuel is evaporated from the fuel lines dues to the heat and the regulator doesn't top it back up, causing a hard start on hot, but possibly also on cold like mine...
    I am going to change my fuel pressure regulator soon coz i got a hard start, checked everything and can't seem to put my finger on it. I'm hoping this is it!
    But yeah, possibly fuel pressure regulator, that's my ywo cents.
    Oct 2003
    me too CAS.......hot its probably the crank angle sensor, first thing to look for with no spark.
    about $70 and 1/2 hour of time
    remove the belt, 3 arm puller remove balance wheel, replace cas, put balancer back on, put back belt, done, start driving. 3 arm puller, you need more instruction on if not pulled one before.
    probably find the car goes a lot better than it has for a while. before they go they seem to effect the timing and power. sometimes for months before they give up. sometimes they cut out randomly and restart later,when cooler. but gets worse and worse. sometimes they just stop.
    tech 2 would pick up the error code to confirm. but i would just do it.
    VT Berlina Wagon S1
    Oct 2008
    Doing the quick "lead off sparkplug and crank it" check will narrow down the possibilities real fast, it will confirm whether there is spark or not... got spark, look at the fuel system... no spark, check out the ignition system.
    Beats swapping out a good part just to find out it wasn't the cause of your problem.
    Oct 2003
    The real way to avoid getting wrong parts is to get the DTC codes read. that will tell you what sensors are faulty. This really saves time and money especially if you have a reader yourself.
    If that comes up with none, then it can be things non sensor related. pump etc.
    the symptoms sound very much like the crank angle sensor. although fuel pumps can do a similar thing, not as common as it pointing to the crank angle however..
    can we take bets on it?
    report back your solution so the loosers can pay up.
    Mar 2008
    hey its deffinately the crank angle sensor. just got mine fixed last week. mine was doing the same thing aswell
    VX Executive S2
    May 2006
    Frankston South Vic
    My money is on crank angle sensor
    warm car up, then turn it off, if it doesnt start pour some cold water around CAS then see if it starts
    or when car is cold use a heat gun (or the wife's hairdryer) to heat up CAS and see if it starts
    CAS will not always log a code
    VT Executive Wagon
    Mar 2008
    Hey guys, thanks for the help. It was the CAS. The rattle gun wouldn't get the balance wheel and i didn't have a breaker bar to do the old 'put the bar on the chassis and crank the motor' trick so i took it down to the local mechanic, charged $120 supplied and fitted...
    Annoying, knowing that i could have done it myself and had to pay someone, but its all done.
  1. VX Series 2 Executive - Start Issue + Boot Button Issue!
    By stig1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-06-2008, 02:28 PM
  2. warm start trouble
    By reardo_202 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-12-2007, 02:14 PM
  3. VR stuggles to start when warm??
    By Famine in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-08-2006, 11:01 AM
  4. VY doesnot start when warm
    By RichardW in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-03-2006, 12:32 AM
  5. VT does not start when warm
    Last Post: 22-03-2006, 10:00 PM
