Results 1 to 13 of 13
Thread: LED Dash Lights
    VT Executive
    Jun 2008
    Smile LED Dash Lights
    Hi,
    I've tried contacting phreddy but i havent got any replies. If anyone knows, it would really help cause it'll save me pulling my dash apart.
    Pretty much i'm just generically saying: anything that's green, I want it to be blue.
    I presume that some of the back light in the cluster will just be wedge globes - does anyone know, are they T5 or T10 mm? Or are they LEDS?
    I presume that behind all the buttons are leds? is this right? (mode switch, a/c etc).
    I'm not going to touch the display screen for now, i'm not confident enough in myself, i'd probably melt it somehow...
    Did that arrogant attitude come with your falcon, or was that an optional extra?
    wrx884's Avatar
    wrx884 is offline WA's ASR Rep
    VT Commodore Exec/5L VP Calais
    Mar 2006
    have a read through this
    Blue LED Dash Conversion
    u'll have 2 b a lil pateint with pheddy hes a busy man and also has his own life 2 run so give him a lil nudge if he doesnt respond somtimes mail gets lost in the 100 PMs he gets a day lol
    Check out my ride in progress.... 98 VT V6, V8 Supercar kitted
    Daily toy.... 92 VP Calais 5L
    VT 5.0 auto
    Nov 2008
    Quote Originally Posted by pill View Post
    Hi,
    they are a combination, & the ones behind your a/c dials etc are different again they are tiny little ones, & the one that lights up your LCD display is different again as well
    btw , if u pull your cluster out, do it with the battery disconnected as i fried my original cluster after i failed to do this , was good excuse to replace with a VX SS cluster
    hth
    VT Executive
    Jun 2008
    Default thanks guys
    I'll have to buy the t5 and t10 led globes off the internet, does anyone know how many i need to get / can reccommend any place other than crazysales.com.au to get them from?
    Also, i've been reading through a haynes repair manual, do you really have to take the sterring wheel off to get to the instrument panel?
    Static89's Avatar
    Static89 is offline I Am Ironman.
    VT Berlina S1
    Jul 2008
    Sherwood QLD
    dont think so o.0 when i had my dash facasia(spelling) out it looked like a few more screws n the whole thign came out
    ParkwayDrv: the worst thing for a hangover would be vkc
    wrx884's Avatar
    Mar 2006
    Depends on a number of things as 2 how many u need. R u only doin the cheap way and replacing the globe only? if so heres a simple list, but ur main thing u urself need 2 check up on is wat type of heater control PCB board u have? theres 3 types only way 2 tell is if u pull it out and have a look.
    Cluster: 5 globes
    LCD screen: 1 (base models) 3 (higher end models)
    All switches: 1 globe each (hazard, fog, trac, power, rear window switch, mode button ect...)
    Auto: 1 globe
    Power window switch block: 4 LEDs (not globes)
    Ignition ring: 1 Globe
    Heater controls unit type 1: 6 globes
    type 2: 7 globes
    type 3: 7 globes
    Climate control: 6 globes
    Headlight switch: 3 globes (soldered in place)
    Bare in mind as mofo sixx said all these globes vary in size and shape so u may need 3mm LEDs in some places and 5mm LEDs in others.
    With the steering wheel no it doesnt need 2 b touched u only have 2 lower the steering wheel and thats it, then the dash surround is able 2 b removed freely.
    ebay is prolly the best bet 2 buy LEDs in bulk form.
    VT Executive
    Jun 2008
    Thanks heaps. I'll keep you posted when i get a chance to pull it all out and get it done. As i work in retail itll probably be after xmas
    vx s pac
    Nov 2008
    When you say globes... do you mean to replace them with LED's ? would the LED's burn the LCD display?
    wrx884's Avatar
    Mar 2006
    Quote Originally Posted by kizza_VL View Post
    no they wont they opperate much cooler than globes
    vx s pac
    Nov 2008
    So you just need to replace all those listed globes with blue LED globes?
    wrx884's Avatar
    Mar 2006
    read the thread i posted above it will tell u wat u wanna know
    vx s pac
    Nov 2008
    yes i have read that, but it says globes and then on one it says LEDS not globes.. so i was just wondering do you replace all of them with LED lights.
    LightningVP is offline Donating Member
    None
    Sep 2008
    replace all of them with LEDs
  1. No interior lights, dash lights or elec windows vk
    By ported in forum Electrical Wiring / Questions
    Last Post: 18-09-2006, 05:10 AM
  2. No Parkers, Speed Alert, dash lights or shifter lights.. Help..??
    By Grommitt in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-04-2006, 10:36 AM
  3. Dash Lights & Tail Lights fail
    By robert_buntine in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-08-2005, 05:17 PM
  4. Custom Dash + Coloured Dash Lights?
    By ViperVp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-03-2005, 09:08 PM
