Results 1 to 12 of 12
Thread: Uh oh. Engine ****ed?
    VT Executive
    Oct 2008
    Default Uh oh. Engine ****ed?
    I have a VT ecotoc 3.8, 250,000k's serviced regularly.
    No real mods, just 2.5" cat back, pacemaker extractors
    Was cruising along today, about 70k's an hour, put my foot down a lil bit and then D D D D D D D D D D D D D.
    It's like... whenever it gets over 1500 revs it makes this wierd noise like its missing hardcore.. sounds like a ****ing boat.
    I drove it home about 500m luckily i was almost home.
    It has fuel, oils are fine.
    Someone told me it could be the catalic converter as its still the old one and they lock up?? O_o
    The engine idles fine its just when you put your foot down in gear, it misses hardcore, i cant explain the sound its not a knock from the engine, its the exhaust and the car is slow as ****
    arghhhhhhh hate my life
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    VT Executive
    Oct 2008
    ****, how do I do that.
    I just spent 877 getting a "big service" done a month ago, cant believe this ****
    i told him to replace all the spark plugs and leads
    thanks for the reply
    Oct 2003
    could be the cat has **** itself, it happens and you get those symptoms.
    does it rattle..short term fix take it off have a look if stuffed bash the core out, put back on. get a new or 2nd hand one later.
    Set of thongs
    Dec 2005
    Stonedville
    877 for a big service? hahaha burnt, sumthing to learn to save ya hard earnt cash, a magor service ya self should only cost u about 200 all up
    fitz_vt's Avatar
    fitz_vt is offline Pass Me A Wrench.....
    VT Commodore SII Olympic Edition
    Nov 2008
    Adelaide - South Side
    Quote Originally Posted by 003KWK View Post
    ahm.... under your bonnet to the right when facing the back of the car you have the black square packs with 1 2 3 4 5 6 on them theyre your coil packs the leads running from that are the spark plug leads
    make sure they are on the coil packs properly.
    for the spark plugs get a 16mm spark plug wrench(from your local supercheap or repco) and undo them ANTI Clockwise and then when your return them to the engine turn then clockwise (hand tighten until tight then do 1/16ths of a turn or 1/4 of a turn if you have spark plug gaskets
    |VT Olympic Edition 3.8L Ecotec | VY S Pack Green Interior|
    Mods to come | VY Map Reading light/Sunnies Holder|
    "Give me a minute, I'm good. Give me an hour, I'm great. Give me six months, I'm unbeatable."
    VT Executive
    Oct 2008
    Quote Originally Posted by Zuicider View Post
    it come with a new glove box hinge, and a seat adjuster clip which was expensive.. high quality sparks, new leads etc i wanted all that ****
    VP Executive R-spec
    Jan 2005
    VT Executive
    Oct 2008
    Hopefully thats all it is, im gonna check it all out tomorrow...
    if its ****ed i'll drop an LS1 in her
    VX Calais 01 3.8lt Ecotec
    Jul 2006
    You really need to learn those things yourself. Get a both a Haynes and Gregories together (workbook) from Repco, Supercheap etc. Who did the major service for you ? Best time to do a service anywhere is when they ahve the voucher on the back of the shopping dockets "$200 Full service at Booran Holden etc" or sometimes Ultra Tune drop em in your mail box then i would do it as they may include coolants flush etc etc. Even then since doing my own oil changes, filters, plugs etc, i only go the mechanic if something brakes and i cant find out what, most suspension things that i need a hoist for/hard to reach places underneath etc.....
    VT Executive
    Oct 2008
    one of the leads coming out of the engine fell off :/
    all working fine yew
    fitz_vt's Avatar
    Nov 2008
    good to hear it was only something small
  1. Engine died at 100kmh then check engine light up ?
    By calaismity in forum VE Holden Commodore (2006 - ?)
    Last Post: 17-05-2011, 09:58 AM
  2. help needed identifying an engine based on the engine number
    By V6_Lux in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-02-2008, 01:25 PM
  3. VN Engine - Signs of failed engine valves
    By nolim8ts in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-04-2007, 07:15 PM
  4. ALOT of engine movment... not broken engine mounts
    By commy92 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-04-2006, 10:14 AM
  5. Engine stalls and engine light comes on.
    By tysons_2001 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-03-2006, 08:01 PM
