Results 1 to 9 of 9
Thread: Will this fit
    Static89's Avatar
    Static89 is offline I Am Ironman.
    VT Berlina S1
    Jul 2008
    Sherwood QLD
    Default Will this fit
    ParkwayDrv: the worst thing for a hangover would be vkc
    Full Spectrum's Avatar
    Full Spectrum is offline Customize your life.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    Fit easy. But your berlina should have the display in the middle ?. I was positive the VT S1 had that working ?.
    Quote Originally Posted by Yoda
    Do, or do not. There is no 'try'.
    <img src=http://forums.justcommodores.com.au/signaturepics/sigpic440_66.gif border=0 alt= />
    Static89's Avatar
    VT Berlina S1
    Jul 2008
    Sherwood QLD
    accentstencil's Avatar
    accentstencil is online now Donating Member
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    I don't think it will work. You will probably need to upgrade the BCM to that of a Calais or Statesman.
    MY RIDE
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    Quote Originally Posted by VT_Berlina89 View Post
    nah man, hasnt got it
    Yep your right. Only series 2.
    Changing that bcm might give you a few more options.
    Static89's Avatar
    VT Berlina S1
    Jul 2008
    Sherwood QLD
    how much is a bcm from a series 2? and how hard of a job is it to swap? do more research into this i must
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Get them cheap on ebay. The link below is an example only because it is from a VX Calais, it may fit a VT but I wouldn't have a clue. You will need to do some research about whether the plugs are the same on a high level BCM.
    If everything fits ok then the change over is easy but you will need to go to Holden to have the BCM and ECU linked. you will also need the keys that go with the BCM you buy.
    HOLDEN COMMODORE VX V6 CALAIS BODY CONTROL MODULE - eBay Other Safety, Security, Safety, Security, Car Parts, Accessories, Cars, Bikes, Boats. (end time 20-Dec-08 18:52:23 AEDST)
    MY RIDE
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    I haven't been able to find one on ebay for over a week. Unless I'm writing it wrong looking ?.
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by SlickHolden View Post
    If you put BCM in search you won't find many, put body control module and you will find more.
    MY RIDE
