Results 1 to 8 of 8
Thread: rear seats
    HVXII's Avatar
    HVXII is offline AWI11
    2002 VXII Acclaim storm grey
    Jan 2006
    brisbane upper kedron
    Default rear seats
    ok i neeed to fix my driverside rear seatbelt & by the looks of it the back seat needs to come out how does this happen & then is it just the reverse action putting it back in. (sorry if this has been done b4 i tried search but nudda)
    thanks guys & girls
    Ford Escort me to a Holden dealer.
    GO drive on australia
    accentstencil's Avatar
    accentstencil is online now Donating Member
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    There are 2 handle things under the bottom part of the seat, one on each side. You might have to lift the front of the seat a little to find them. Pull these handles down towards the floor while lifting the seat, one side at a time, and then it should come out. Then remove the bolts that hold the backrest in place and unhinge the top.
    MY RIDE
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Very hard to remove the bottom cushion if you follow the instructions given in workshop manuals. Easiest if you slip your hand in between the cushions towards one side. Pull the rear of the bottom cushion upwards until it clears the bottom of the back cushion. Do the same for the other side. You can then easily move the bottom cushion forwards and off the two brackets that hold it at the front. Once the bottom cushion if off you will see the bolts holding the rear cushion and can remove it as well.
    Oops, sorry, forgot I had changed forums, thought that I was still in the VR/VS forum. Haven't had the need to remove a rear seat in my VX yet.
    HVXII's Avatar
    Jan 2006
    Thumbs up
    thanks heaps spot on the money
    '00 WH V6
    Dec 2005
    Old thread sorry.
    Does anyone know if you can get away with just undoing one side to get into the rear seatbelts?? Reason being I just had baby seat installed a couple of days ago,,, really don't want to be ripping it out already.
    Driving a CURSED WH V6.
    '00 WH V6
    Dec 2005
    Old thread sorry.
    HVXII's Avatar
    Jan 2006
    the whole of the bottom bit comes out in one peice but the 3 back rests all come out separate
    '00 WH V6
    Dec 2005
    Awesome
    Just a trip to bunnings in order to get the bolts out (I only buy really cheap tools, i ALWAYS lose them).
    I did have a look today, but it still wasn't clear how the back rests came out...
  1. VS rear seats
    By Ratten in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-08-2008, 08:32 PM
  2. how do you remove the rear seats??
    By pedrotski in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-07-2008, 11:25 AM
  3. VT Rear Seats
    By HoZy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-04-2007, 11:11 PM
  4. Will VN rear seats fit in a VK?
    By synoptica in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 09-02-2006, 10:17 AM
  5. Rear Seats in VK
    By Jeza in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 20-04-2005, 10:29 PM
