Results 1 to 4 of 4
Thread: VT Front Bearing Noise
    VT Executive Wagon
    Nov 2008
    Upper Caboolture
    Default VT Front Bearing Noise
    I have a VT wagon that has a noise like grinding coming from the front left. The noise only happens when steering right hand down like on a round about or sweeping right bend. It is also noticeable when driving straight. Left hand down & the noise disappears.
    It is not constant, seems to be like grind, grind, grind, no noise for split second then it does it again. It is a sharp short noise.
    I thought it might be the bearing on that side. Has anyone else struck this problem? What is the remedy?
    Steve
    pablo is offline Donating member
    Was a 1997 vt v6 wagon
    May 2006
    Jack up that corner and take the wheel off and spin the hub, feel and listen for roughness in the bearings. You will probably have to push the brake pads off the disc a little bit so as to have no drag.
    Pablo
    3.8L GT35 4runner/VK calais
    Dec 2006
    Nowra
    VT Executive Wagon
    Nov 2008
    Upper Caboolture
    Thanks for the advice, did just that Pablo & we noticed a definite difference between the 2 front wheels. I shopped around on price and in the end had it fitted at the local Ultra Tune who i know through the local Chamber of Commerce. All is good now, NO NOISE!!!
  1. vt ss front wheel bearing noise
    By rox in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-12-2008, 03:07 PM
  2. rattling, grinding, bearing noise
    By TIL52 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-05-2008, 06:59 PM
  3. Wheel Bearing Noise?
    By chromic in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-11-2007, 02:50 PM
  4. bearing noise
    By homer simpson in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-10-2007, 04:00 PM
  5. Bearing noise V8
    By tollmeyer in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-01-2006, 09:28 PM
