Results 1 to 6 of 6
Thread: Upgrading alternator to battery connection
    VX Commodore Lumina
    Jan 2006
    South Adelaide
    Default Upgrading alternator to battery connection
    Is it simply done by adding a wire (I'll be using 4 gauge) from the bolt at the back of the alternator, to the positive terminal on the battery? Will this actually help at all, or is it just a redundant addition?
    Thanks in advance
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Is there a real need to do this, whats wrong with the standard one. Did you whack in in a bigger alt. If not, just make sure its crimped nice at the alternator in the lug and the battery end it tight and it should be all good.
    Reaper
    VX Commodore Lumina
    Jan 2006
    South Adelaide
    Oh ok.. I've just read on the12volt.com that it's a good idea to do this (upgrading 'the big three'). I just want to do everything I can to stop the bloody headlights dimming with bass hits. I've upgraded my earthing, but I thought this my help to. If not then that's ok, I won't waste my time with it .
    VrWagz1's Avatar
    May 2008
    wollongong
    The alternator main wire wont make a difference to your lighs dimming with bass. A quality battery with oversize amp main wiring is the only things that will make a big help. Make sure your earth point for the amp is clean, no paint and a tight conection. The only original wiring you should have to upgrade for that is the earth wire that goes from the chasis next to the battery to the battery negative terminal.
    Reaper
    VX Commodore Lumina
    Jan 2006
    South Adelaide
    ok then thanks for that. I've added an extra 4gauge that's roughly 10cm long from the negative so maybe that's all I'll have to do? Although if I've got more 4gauge left over, I do plan to add another couple. Guess I don't need to worry about much more in the engine bay then, thanks .
  1. upgrading battery terminal
    By Denno in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-11-2008, 01:04 AM
  2. Not turning over properly - battery connection?
    By javt99 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-07-2008, 11:22 AM
  3. Upgrading Alternator wire...
    By Chirpstr in forum Electrical Wiring / Questions
    Last Post: 16-06-2008, 08:34 PM
  4. upgrading alternator in vk 202
    By bezz in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 03-04-2007, 10:40 AM
  5. battery or alternator??
    By Snotty in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-12-2005, 12:07 PM
