Results 1 to 8 of 8
Thread: mixing mufflers..bad idea?
    Jul 2006
    Default mixing mufflers..bad idea?
    hi guys. i could be completely wrong here, or it might not even be possible, but i bought an xforce exhaust a few months back and didnt like the sound (super6). anyways, is it possible, and would it sound alrite, if i mixed the front muffler from my stock exhaust with the back 2 from the xforce.
    is this possible, and will it sound really **** or what? im after a slightly quieter sound than what the xforce produced.
    thanks guys
    VT
    Apr 2005
    QLD
    You say the XForce had TWO rear mufflers? Odd.
    There is no problem whatsoever in mixing and matching mufflers, i'm surprised a lot more people don't do it. There really are so many variables in an exhaust to make it sound different at various rpm's....amount of bends, size of bends and tube, expansion tubes, etc etc. Go for it.
    Jul 2006
    Sorry... two front mufflers! Might give it a try then. Also.. one more quickie....i cant get the exhaust split in two. They used a white adhesive past.. is this a bonding material? Me and a mate tryed to split it but couldnt... any tips?
    VT
    Apr 2005
    QLD
    Those two front 'mufflers' you speak of are your catalytic converters. Leave them be. There is no problem at all with changing your muffler to get the sound you desire. As for the flange sealant, most are incredibly strong, i've tried leaving bolts out of a flange and operating the vehicle and it stayed intact. Best bet would be to put one or two bolts in loosely and push against it with your foot to dislodge it or hang your body weight off the joint.
    Jul 2006
    Ok will give that a try. Nah not talking about the cats mate, the two mufflers after the cats.
    VT
    Apr 2005
    QLD
    Quote Originally Posted by lockmac View Post
    Ok, so you're shooting for 3 mufflers all up? that should fix the noise issue, you might end up being too quiet, almost back to stock depending on the mufflers you use.
    Jul 2006
    welll both my stock setup and my xforce has 3 mufflers... one for each pipe just after the cats and then one main muffler near the tips
    Farlig's Avatar
    Farlig is offline Donating Member
    Y-Series Clubsport
    Jan 2005
    the rear box is generally a resonator, stops pops and crackles in exhaust during deceleration normally.
  1. Mixing BodyKit Parts.
    By HÝPÕ-5L in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-01-2007, 09:49 PM
  2. Mixing fuel?
    By tonitrus in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-02-2006, 12:48 PM
  3. mufflers...which is right for me.
    By down_with_the_system in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-01-2006, 10:39 PM
  4. mixing coolants
    By GeorgeB in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-08-2005, 07:36 PM
  5. VN mufflers
    By mickah in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-02-2005, 09:52 PM
