Results 1 to 9 of 9
Thread: VT DRIVERS SEAT Headaches
    VT 2
    Nov 2008
    Default VT DRIVERS SEAT Headaches
    Like everyone else probably, My drivers seat cushion has collapsed on the right hand side on th ebase. Ive already swapped out this seat once and lost my Drivers side airbag, now the cushion has gone again and I'm wondering what the hell to do.
    Ive had one seat repadded and it lasted about 6 weeks. The seat I swapped in was an SS which had better sides but the base still sucks.
    Is there a better tougher later model seat i can swap in that ideally retains the drivers side airbag, but gives me a better seat ?
    coasty's Avatar
    coasty is offline the voices told me to
    vz equipe & vt berlina both v6
    Feb 2008
    kanwal nsw
    mines still perfect. i just have problems with the back adjuster breaking.
    Mercedes C200K AMG-Sports
    Mar 2007
    I have heard the VY seats will fit (confirm this)... also the VX
    Not sure if they are better quality. I've never had an issue with my VX seats. Yet I am a light weight guy.
    bdj_007 is offline Foose
    2002 Holden VX Equipe SII
    May 2008
    Beaconsfield
    VT S2 wagon Berlina
    Dec 2008
    can you just remove the seats. what happens about the air bag. is it safe to remove and it wont go off.
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    Disable the air bags the same way you would if you were removing the steering wheel. It's then perfectly safe to remove the seat.
    BOGANV8's Avatar
    BOGANV8 is offline I gotta V8 whoot whoot
    VX 02 SS LS1
    Dec 2005
    Armidale
    Mine too have collapsed so yeah VY might be the way to go
    Doe the seatbelt buckle on the seat of a VY still have the same plug for the pre tensioners.... as the vx..
    VT S2 wagon Berlina
    Dec 2008
    sorry I dont know how to remove the steering wheel.
    is it the disconnect battery.
    leave 30 mins and then pull the seat out but never turn the ignition on while the seat is out ?
    thanks new to owning a vt commodore.
    BOGANV8's Avatar
    VX 02 SS LS1
    Dec 2005
    Armidale
    edit just read you had side airbags.....
  1. VT Drivers seat
    By GMBanisher in forum Swap / Wanted to Buy / Trade
    Last Post: 11-09-2008, 08:19 PM
  2. Removing Drivers Seat with AIR BAG
    By vz 914 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 06-03-2007, 08:58 AM
  3. Vn drivers seat moves
    By BeaversVN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-08-2005, 02:15 AM
  4. Removing drivers seat
    By Sahab in forum VY Holden Commodore (2002 - 2004)
    Last Post: 14-04-2005, 10:03 PM
