Results 1 to 9 of 9
Thread: A/C Not Working
    Hardstylin is offline Banned
    VP Calais
    Aug 2008
    Melbourne, Victoria
    Default A/C Not Working
    The air conditioner in my sister's VT Calais is not working, the air only comes out of the front demister vents, and the air is hot.
    Any suggestions?
    VTvoodoo's Avatar
    VTvoodoo is offline 99 VT S2
    VT Executive S2
    May 2006
    Gold Coast
    not totally sure, but mine isnt working either, and im told my compressor is stuffed , so thats one option :P ..u could try typing in "Air conditioning" in the search function , theres alot of threads relating to a/c probs
    so to hijack this thread somewhat, but has anyone replaced there compressor with a ashdown ingram compressor , are they any good?
    accentstencil's Avatar
    accentstencil is online now Donating Member
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by Hardstylin View Post
    Any suggestions?
    There could be many reasons why the A/C is not cold. The main one being, low on gas. Also a faulty pressure switch, a blown fuse, slipping belt, compressor clutch or the compressor itself.
    The vent position problem is probably due to there being no vacuum. Check that the thin vacuum hose a the rear if the intake manifold is connected. There are other things it could be but we'll start with that.
    MY RIDE
    VT Berlina Wagon S1
    Oct 2008
    Then... further down that thin vaccuum hose is a solenoid pack, under the fan, behind the glovebox. Those solenoid packs commonly fail too, and when they do, you don't get air coming out of where it should or at the temperature you want. About $60 at GMH for a new one.
    VP Calais
    Aug 2008
    Melbourne, Victoria
    Quote Originally Posted by accentstencil View Post
    Thank you for the response, although I'm not quite sure where the intake manifold is.
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    the intake manifold is the big thing that is in the cente on top of the engine, it takes up nearly all of the top of the engine. You will need to remove the engine cover (if you have one) to see it.
    MY RIDE
    Static89's Avatar
    Static89 is offline I Am Ironman.
    VT Berlina S1
    Jul 2008
    Sherwood QLD
    o.0..... you know the air box?? thats the black thign on the right as you look into the engine bay, follow the black hose, and it goes under the engine vcover, under the cover is the intake look behind that for a thin tube
    ParkwayDrv: the worst thing for a hangover would be vkc
    VP Calais
    Aug 2008
    Melbourne, Victoria
    Quote Originally Posted by VT_Berlina89 View Post
    I know what the CAI is. I took off the engine cover and all the hoses and tubes seem to be intact and connected.
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    The hose I'm talking about is very thin and at the rear, you can't see it from the top. You have to look at the back, near the firewall.
    MY RIDE
LinkBacks (?)
  1. 31-01-2009, 01:29 PM
  1. Fan not working
    By Old fart in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-10-2009, 05:50 PM
  2. lpg not working
    By vh ~ very horny in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 30-04-2007, 06:26 PM
  3. fan not working
    By danx in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-10-2006, 10:39 AM
  4. Fan not working
    By croz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-05-2006, 09:23 PM
  5. VK Fan not working
    By Kevin in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 23-02-2005, 04:41 PM
