Results 1 to 11 of 11
Thread: vt s pack brake light!
    Vt S Pack Series 2
    Nov 2008
    Default vt s pack brake light!
    hey people! first time posting here so here it goes....
    recently noticed that my drivers side (right) brake light is dim compared to the passengers side. i changed the globe annd it resulted in the same problem...
    anyone have any suggestions to what may solve my problem?
    Lumps of cheese's Avatar
    Lumps of cheese is offline Who wants chowder?
    MY08.5 VE V8 CALAIS/2010 Hilux SR D4 Dual cab 4x4
    Boulder Crusher Champion! Balloon Park Champion! Action Fish Champion! 501 Darts Champion! Frogger Champion! Jungle Kid Champion!
    Nov 2005
    Warrnambool
    Vt S Pack Series 2
    Nov 2008
    naah when i put a in a new globe it goesss all right for about 5 mins and then just dimsss......
    feg
    feg is offline
    VT S S/C
    Jul 2006
    I had a disimilar issue with my brake light that may help. One of my brake lights would go out, also taking out the taillight.
    The bayonet of the brakelight is a split ping and at some point the light had been put put in around the wrong way which made the enclosure split.
    have a look at it and see if the light is sitting in the holder correctly.
    I bought a new one from my local holden dealership, $40.
    Hope this helps.
    Vt S Pack Series 2
    Nov 2008
    ;ive noticed that the socket that the globe plugs into have a tinnny split about a 1cm long...that seriously cant be why its dimming tho can it?
    Ozzie's Avatar
    Ozzie is offline JCCC Warrnambool
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    most likely its an earthing issue.
    clean the connections inside the harness's and globe sockets and make sure the earth wire isnt damaged. If u still have the problem then run another earth wire from the globe socket to some bare steel on the chassis and see if its brighter then
    Vt S Pack Series 2
    Nov 2008
    funny you say that my magtes older brother whose a mechanic mentioned that it may be a earthing issue...can i just clean the wires with a damp rag of hot water? or what?
    Ozzie's Avatar
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    Quote Originally Posted by pac3y View Post
    if you can... try to use some sandpaper or nail file or something.
    water isnt a good idea as it will corrode the contacts even more.
    metholated spirits will work but in the long term it will also corrode the contacts.
    so the best method is to sand the layer of crap off the contacts
    Vt S Pack Series 2
    Nov 2008
    hmmm well i took a look at the bulb when it was plugged in but with the cover off annd when ive got the accessories on the light doesnt seem to be bright. when you put your foot down on the brake one of the electrodes? in the bulb light up fully wheresas the accessories one behind it doesnt light up that much. you can see a differecne when youve got the brake pedal depressed beccause they both have current running through them. soo it cant really be a grounding isssue.
    i took a look at the passenger sides buld and it says 5watt but its got 21v whereas the dimming one has 5w but has 24v on it?
    Phreddy's Avatar
    Phreddy is offline Bye SV6 - still love you
    VS-II Statey-8
    Apr 2005
    W-Sydney NSW
    LOL!! It's a 24V globe!! Probably for a truck - they run 24V systems.
    That's why it's so dim - 12V can only push half the current through it, so only half the power. When a globe filament is only running half its rated power it's putting out less than 25% of the nominal light!
    Change it for a 12V globe, and it should be sweet.
    (also, take the 24V globe back to the dodo who sold it to you, lube it up a little, and jam it up his clacker!!)
    New look ASR Website online now!!
    www.asr-audio.com.au
    Interior lighting and audio specialties
    for VT/VX & VY/VZ Commodore / Monaro
    NOW VE DASH LIGHTING CONVERSIONS!!
    PLUS TECH2 DIAGNOSTIC SERVICES
    JBL Car Audio dealer
    Vt S Pack Series 2
    Nov 2008
    haha that would explain alot....as for that dodo that sold it to me super cheap or should i say super crap! i never really trusted the stupid 17 year old behind the counter!!!!!
    thank you thank you thank you!!!
  1. Third brake light in a ute
    By one_and_only2004 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 06-10-2008, 09:49 PM
  2. vr calais head light and interoir light brake problem
    By lestat2220 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-08-2008, 01:38 PM
  3. VZ third brake light
    By lacy18 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 06-09-2007, 10:44 AM
  4. wtf brake on light on
    By HDT_aero in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-05-2005, 02:07 PM
  5. brake light
    By statement in forum Electrical Wiring / Questions
    Last Post: 27-06-2004, 09:21 PM
