Results 1 to 5 of 5
Thread: Window
    Static89's Avatar
    Static89 is offline I Am Ironman.
    VT Berlina S1
    Jul 2008
    Sherwood QLD
    Default Window
    i have a vt berlina and im having a problem with the rear right window, its staying down, not moving seems like i have burnt out the motor because neither of the switches are working on it, seeing as its not going to go up unless i get a new motor for it, it there any way i can manually lift it and fix it in place? or does it have to be via the motor?
    ParkwayDrv: the worst thing for a hangover would be vkc
    VT Berlina Wagon S1
    Oct 2008
    Remove the switches and short the contacts, this will rule out the switches being good/bad.
    Check the door loom, where it goes to the pilar on the body. These will break with time, mine did because Holden fitted it poorly and it was too tight (metal fatigue in the wires will kill most door looms anyway).
    Hot-wire the motor, right at the motor with some jumper leads (or scrap wire, whatever), this will test the motor (be sure to disconnect the motor first). If it works the problem is in the loom somewhere, if it doesn't work the motor is duff.
    Static89's Avatar
    VT Berlina S1
    Jul 2008
    Sherwood QLD
    ok kool, im thinkn the motor or the loom becoiuse neither of the switchs work
    VT Berlina Wagon S1
    Oct 2008
    A mulitmeter is a handy tool to have... Jaycar, Dicksmith, etc have cheapies for about $10... great for occasion use, and they'll pay for themselves fast.
    VT C/SPORT 5.0L 5Spd
    Aug 2008
    Search thread for power window sticking, some detailed help descriptions there.
    The mech, usually just gums up with dust over time, try lubing the parts of the wires that u can grab by hand. Give the window a pull and try to operate the switches, u may get movement.
    The motors dont bust that often, usually just gum up and reach a stocky point they can pull past try help the window while operating the switch.
    Metho squirted into the switch mech will remove burnt bits that build on terminals and eventuall fail, make sure you remove the part from wiring first and dont use until dried out properly.
    Finally if you do have to replace the motor good luck. Original motor are riveted into door frames.
  1. vt single window to 3 window dash conversion
    By daz_vt_98 in forum Electrical Wiring / Questions
    Last Post: 06-11-2008, 12:17 PM
  2. Replies: 18
    Last Post: 03-11-2008, 04:12 PM
  3. Changing 1 window to 3 window trip computer. VY Series II
    By Krustyone in forum VY Holden Commodore (2002 - 2004)
    Last Post: 12-11-2005, 05:55 PM
  4. single trip window to triple window
    By m_nairn in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-07-2005, 08:10 PM
  5. Rear window seals are coming loose, window is rattling whilist driving.. how to fix??
    By t3zza in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-05-2004, 11:58 AM
