my battery seems to be leaking acid , which is no good, so ill replace it , but other than a faulty battery, is there any other reason that would cause this? before i go out and buy a new one, sits on 12.6v and when running 14.3v , so i assume its not overcharging?
also what are the round about prices on those closed cell types, optima etc? for a v6
it can leak if it is filled too high with water , if it is overcharged , or if the caps are loose.
There's a recent battery thread on here... try the search. Some say Bosch Gold batteries are good ( I have not tried them myself )!! ?
I think an optima yellow top is around 3-400
How to be a good Australian Citizen: Drive a Camry, Become another number in the system, Dob in all other numbers for un-numberlike behavior (no matter how slight), Base all your opinions solely on the information provided by T.T. and A.C.A., Believe everything our gracious Government Tells you to.
thanks for your replys, hmm yeah i did top it up a while back, when i was having starting troubles (ended up being the alt) so that might be the prob , ill keep an eye on it , otherwise ill have a look into the bosch gold's
just one more Q, how do u tell if its overcharging?
if the alternator is producing 14.4ish volts then it should be fine.
If its producing something higher then normal like 18v then the rectifier on the alternator's gone
