This is the most annoying thing out..
when the aerial stops going down or up as far as it can go.. it tries to keep on going.. and makes a very annoying clicking/clunking noise.. anyone know how to fix it or do i have to get a mechanic to fix it?
thanking you in advance :P
sounds like the last tooth on the plastic ribbon//extender//retractor has worn out... you can get replacements for about $40 from Supercheap/Autobarn//Holden//etc. (comes with shiny new arial and the plastic ribbon//extender//retractor thingy)
yer.. rp7 seems to fix everything :P.. but yer i'll give that a shot.. and if that fails i'll go to supercheap..
fail.. RP7 didn't work.. but as i found out it has a slight bend and that seems to be the issue.. so i'll just have to get a new aerial
.. cheers for the suggestions guys
Car theives should be treated just like horse theives and cattle rustlers in the days of the wild west... Hang them!
Don't be stupid. Power isn't measured by the size of your tacho
man exactly the same thing as me.
i tryed wb-40. used half a can...useless
mine also has a bend in it.
i was quoted 80 bucks for a new aerial.
Picked one up for my VS today. They sell at supercheap for $149but I got it a bit cheaper (thanks RACV). It looks like itll be a pain to fit so I'll see if I can get a mate to give me a hand some time in the next few days
:O
that madness
ebay!!!
ive heard there a bitch to get in
so keep us posted
That price includes the motor and mast, but they had ones to suit other cars for much cheaper. No idea why commodore ones are so expensive.
I'll post up here when I get it in. Just might not be for a few days. I've lived with it for the last few months, I'm sure a few more days won't hurt
$149 for a new aerial is bloody expensive. When I had to replace mine on my VX, I went around toall the stores (WOW, Autobarn, Supercheap, etc) they all wanted $120-$150. So I checked with Holden and they only charged about $90 for a brand new one for a VY which is exactly the same.
Was a bit hard to put in, but not too much. About 1.5 hours if your brother keeps giving you bad and unwanted advice.
Just remove the wheel, take out the guard and all the parts are right there for you. You will also have to move the ECU out of the way to get to the connectors. But all together not too hard. The kind of job a few drinks go well with.
-Adrian
Ronald Reagan (1986)
lol.. i haven't had my car for a while.. and it is still under the 3 month warranty.. i'm guessing this would come under the warranty, right? stupid question i know.. but i'm sure the dealers always try to be stingy..
What's wrong with giving the bent sections a bit of a bend the other way to straighten it? Easily done with care, a squirt of WD40 and it should be all good again.
lol.. dam u serious? well that sucks.. its harder than you think.. cause u have to apply the right pressure, if its too much u bend it too much..
I doubt they would replace it under warranty as well, but it's always worth a shot.
I spent ages straightening mine up, and it looks just about perfect but still doesn't work. The mast is fairly strong, and the motor doesn't have the guts to straighten in as it all collapses inside itself.
And of course if you bend it too far it doesnt take much before it gets weak and breaks
Installed the Aerpro one this afternoon. The mounts on the new aerial were different to the standard one, so I couldn't use the original bracket or hole, but I was able to bend the crap out of the bracket that came with the new unit and squeeze a drill in there to make a new hole.
Wiring and everything like that was pretty simple, just plug and play.
The motor on this unit is a bit noisier than the original, but at least it goes all the way up and down now.
For anyone else doing this, using a genuine unit would make it 10x easier, but it isn't overly complicated, just fiddly.
If anyone wants I can try writing up a bit of a how-to or just put up some pics, but I'm sure there are better ways to do it than what I did.
lol i fixed the issue :P.. just unplugged the wire that made the aerial go up in the first place.. i just listen to my CD's nyways..
